Stumbling 302HO
Old Sep 4, 2003 | 09:36 PM
jpourner's Avatar
jpourner
Stumbling 302HO
I just finished re-building an 86 302 HO engine with a Holly 600CFM carb and found that I had to shim the rockers .025 to get the valves to close all the way the vacuume is 14 lbs at idle ( I think it should be closer to 22 lbs).
The problem that I am having is that when I get on the gass from a dead stop the engine will stumble real bad and at times it has died .
Any ideas as to what may be the problem?
Thanks for the help.
Old Sep 4, 2003 | 10:28 PM
Chris_ce's Avatar
Chris_ce
Stumbling 302HO
What did you do to the engine? A new cam Whats the lift? New rocker arms whats the ratio? Did you replace the push rods?
Old Sep 5, 2003 | 12:03 AM
DW2455's Avatar
DW2455
Stumbling 302HO
is it a stock cam or performance cam, is the distributor vac. advance or comp. control, and how do you have the timming set. DW
Old Sep 5, 2003 | 12:25 AM
stepman's Avatar
stepman
Stumbling 302HO
O.K. back up. I'm lost here.You shimmed the rockers so that the valves would close?! Haven't heard that one. (not trying to sound harsh here) Something is wrong with that.Maybe wrong pushrods,worn rockers or something. But let's back up. This is carb'ed so is the accel pump working? How's your timing.Vacuum at idle should normally be 14"-18". 18" is hard to get. If you get 16 your doing good. I would look into the carb when you pump the gas. You should see a good strong squirt of gas going down the carb.Make sure your timing is correct. Check your vacuum advance and make sure it is hooked up to the correct source. (manifold vs ported) Maybe you can find something of value in here. I think I've been at it too long.
Old Sep 5, 2003 | 12:32 AM
DW2455's Avatar
DW2455
Stumbling 302HO
yup I'm with you on the shimming thing, that one lost me to, the only thing i ever shimmed on a head period, was valve spring to obtain the corect installed hight and prssure. DW
Old Sep 11, 2003 | 08:31 PM
jpourner's Avatar
jpourner
Stumbling 302HO
Every thing is stock except the pistons ( hyper tech 9:1 .030 over) and the carb Holly 600cfm.
I shimmed the rockers to meet the valve lash requirments in the engine manual.
The accel pump is working great
Old Sep 11, 2003 | 10:34 PM
MuchToMyDelight's Avatar
MuchToMyDelight
Stumbling 302HO
Timing is the next thing to look at.
Old Sep 11, 2003 | 11:05 PM
DW2455's Avatar
DW2455
Stumbling 302HO
could you explain shimming the rockers to get the valves to close? how does shimming the rockers close the valves? DW
Old Sep 12, 2003 | 12:01 AM
90f150moneypit's Avatar
90f150moneypit
Stumbling 302HO
Crane sells shims that you put under the rockers (pedestal mount) to adjust for lifter preload, like these.
jpourner- A few ?'s
What I'm also wondering is, if the cam and pushrods are stock, why did you need to shim? Was there any head work done (milling)?
How is the accl. pump adjusted? You should have a little clearance between the cam and arm (I forget the recommended clearance). If this is a new carb you shouldn't need to adjust this, but if it's used someone may have in the past.
Have you tried adjusting the idle mixture screws on the side of the carb or the float levels?
Where do you have the vac advance running to, ported or manifold vac.?
Is there an EGR?
Old Sep 12, 2003 | 12:10 AM
DW2455's Avatar
DW2455
Stumbling 302HO
jpourner- A few ?'s
Is there an EGR?
but shimming the rocker arm would not make the valves close, is my point, stock motor with 14 inches vacuum at idle? something wrong here to, idle mixture way off, vacuum leak, performace cam to big. ect. ect. DW
Old Sep 12, 2003 | 10:18 AM
90f150moneypit
Stumbling 302HO
Shimming the rocker moves the rocker up, preventing the too long pushrods from opening the valves too early. This was an option for me but I chose to convert to studs. I agree he does have something else wrong.
Old Sep 12, 2003 | 10:38 AM
stepman's Avatar
stepman
Stumbling 302HO
O.K. I understand the shimming thing. What else could be looked at to cause this. Is it that this happens only when you romp it ? If you accel slowly does it do the same thing. I'm thinking not enough initial timing, not enough advance ( I'm assuming a new dist but I prob shouldn't do that) Maybe leaking vacuum advance. Carb opening up too fast. Just some things to think about.
Old Sep 12, 2003 | 11:13 AM
DW2455's Avatar
DW2455
Stumbling 302HO
first thing is you need to figur out this vacuum issue, if you have a vacuum leak, then you'll never get the carb to respond properly, once you have the vacuum issue resolved, stumbling off idle could be that you need a larger center squirter in the carb, possible a larger accelerator pump, or maybe just to adjust the cam on the pumt to give it a quicker shot of gas. Is this carb new, used,? whats the history on it? DW
Old Sep 15, 2003 | 09:43 PM
jpourner's Avatar
jpourner
Stumbling 302HO
Sorry for stayng away to long Uncle sam called me to duty for a couple days.
Yes the head was milled and the machine shop did not grind the valve stims.
no there is not an EGR valve, the moron that I got the engine from pulled off the original EGR plate and carb and stuck on a rigged up 2 bbl adapter plate.
I installed a 1 inch riser that covers the EGR hole in the intake and allows the 600 cfm carb to operate.
The Carb is used but in good condition.
timming is set at 8 deg btdc.
The stumbling only happens from a dead stop and if I romp it.
if I am rolling even a little then every thing works great.
The vacuume advance is connected to the ported vacuume port on the carb.
The only thing I can think of is the 1 inch addapter does not seal the exhaust / EGR hole in the intake.
Old Sep 15, 2003 | 10:32 PM
fordeverpower's Avatar
fordeverpower
Stumbling 302HO
what 86 302 HO has a carb? What is this motor out of?
