1949 F6 239 Flathead Overheating Problem
My truck overheats, especially when under load.
1949 F6 239
The truck sat for 25-30 years. Someone started it up about 5 years ago (new coolant, oil, plugs, wires, etc) It sat again for until I got it.
I put new temp sender in the drivers side head and then I got new tires on it and drive it back 15 miles from the tire shop. It started reading hot. I stopped and let it cool and restarted. It started dumping lots of coolant and I was having to add water every 3-4 miles.
I got a new radiator cap (4 psi). It slowed coolant leak, but it still overheats.
I thought stuck thermostat... got new t-stats and pulled housings. No t-stats installed.
I've:
* checked water flow on each head by removing upper hose, running engine and verifying water flow. Water only flows under acceleration but then its voluminous.
* checked exhaust for restrictions
* drained all old coolant (looked clean), flushed radiator and block with water hose (looked like good flow), currently it has Blue Devil flush in the system.
* gotten Block Tester and tested four times. Blue never changes color
* Replaced all hoses
I'm stuck. I don't know whether to try pumps or buy a repop radiator.
Does anyone have any clue?
--- couple other details to add ---
Doesn't seem to ever get more than 3/4 hot on gauge at idle.
Gauge drops to just under half if I accelerate with no load
It takes about 10 minutes of driving to go from cold to almost all the way hot on the guage
Passenger side head seems to stay cooler longer than drivers side (just by touch when heating up)
Many thanks in advance.
Bram
Are you filling it to the top of the tank? The Full level is at least an inch below the filler neck (some radiators have a brass strip at the proper level. As long as the tubes are completely covered, you're OK.
Aside from cooling system ailments, retarded timing or lack of spark advance will cause overheating.
I pulled the radiator and had it professionally cleaned $65 later and also new thermastats it runs fine and guage never goes up past a "H" which I assume is 180 since that what t stats i put in.
Thanks,
Bram
