Sponsored by: Real Truck
Help! Sway bar bracket broken
Old Jun 17, 2017 | 03:22 AM
mbighorse's Avatar
mbighorse
I have a 2000 F-250 super duty XLT 4x4 and I have a sway bar bracket thats hanging loose. it seems to have been attached some way but it seems as though it was rigged before. keep in mind I got this truck with it pretty beat up. just need help trying to figure out the part I need to put the Stabilizer Bar Bracket to attach. if that makes sense
Old Jun 17, 2017 | 03:31 AM
seville009's Avatar
seville009
This thread has pictures.....not sure if it'll help you figure out where it connects.
https://www.ford-trucks.com/forums/1214533-oe-sway-bar-end-link-replacement-with-pics.html
Old Jun 17, 2017 | 03:37 AM
mbighorse's Avatar
mbighorse
looking for how this originally was attached
Old Jun 17, 2017 | 05:00 AM
seville009's Avatar
seville009
Found this on the internet - shows a bracket that looks like is broken off of yours
i'd take it to a dealer to see if they can identify the missing bracket
Old Jun 21, 2017 | 08:18 AM
M88's Avatar
M88
Mine rusted off the frame!
No more front swaybar
Old Jun 21, 2017 | 08:35 AM
brandon_oma#692's Avatar
brandon_oma#692
Mine had that happen to it. the previous owner just bolted up a piece of flat stock to replace it.
Old Jun 21, 2017 | 08:50 AM
99f350sd's Avatar
99f350sd
You dont need the swaybar if you have stiff front springs...mine has been off for years.
Old Jun 21, 2017 | 08:52 AM
M88's Avatar
M88
I believe this truck has the snow plow prep package on the right side, at least. Was ordered with it. Left side has always sat 1'' lower than right since new. But I towed 7500 pounds or so recently without issue. Felt fine to me.
I use my Jeep Cherokee (coil springs front) as a pickup often with no swaybars either. Works okay for me!
whitesaige
Nov 25, 2017 07:05 PM
Leeet
Oct 1, 2015 08:32 AM
mando jake
Offroad & 4x4
Jul 2, 2009 05:00 PM
