6.2L V8 Discuss the 6.2L V8
Wrong diff gear ratio.
Old Jun 16, 2017 | 11:47 AM
Chuck's First Ford's Avatar
Chuck's First Ford
you stated 4000 Canadian... so you are in Canada !!
I understand .. Canada is more stringent on laws of weight and ratings.. so I have been told.
double check with Ford.
Old Jun 16, 2017 | 12:31 PM
Campout's Avatar
Campout
I'm in the process of getting Ford to supply updated identification door stickers vin? Whatever is required to meet Canadian laws of weight and ratings. This may take some time.
Campout
Old Jun 17, 2017 | 05:06 PM
SnowPlowDriver's Avatar
SnowPlowDriver
I am surprised no one suggested you refuse delivery of the truck. I woudn't be happy with dealer replacing ring and pinions on a new truck.
Old Jun 17, 2017 | 06:28 PM
GSSF17's Avatar
GSSF17
Yes. This.
The vin code would be different and so would the door sticker, etc., if the truck was built as you ordered it from the factory.
Old Jun 17, 2017 | 10:10 PM
Ron94150's Avatar
Ron94150
I told him not to settle for good enough in an earlier post. If they can truly get the door jamb sticker correct for the truck, I wouldn't have a problem with the dealer doing a ring and pinion swap. Someone had to set it up the first time. It's not rocket science, especially if you have all the right tools. If it's not right, he will know it while it's still under warranty. And there's been plenty that weren't right from the factory that were replaced under warranty. I would be more worried about them not doing things like replacing the hub seals, causing a possible premature vacuum leak than the gears themselves. For me, it would sure beat the option of waiting 6-12 weeks for a replacement. Heck, might as well wait for an '18 if your gonna refuse it.
As far as the vin, I don't think it indicates what gears it had, I may be wrong. But I think the I'd tag on the door jamb and the tags on the differentials is all that tells. Someone that knows 100% can correct me if I'm wrong.
Old Jun 18, 2017 | 07:04 AM
GSSF17's Avatar
GSSF17
Ron, you are right and I am wrong. The VIN code will have indicators such as color, engine, etc., The vin/vehicle ID Decal (door jamb sticker) is where the info on gearing will be. Good catch.
Old Jun 19, 2017 | 11:02 AM
Campout's Avatar
Campout
Campout
My conclusion as long as you use original tires the only required change is to flash the computer for gear ratio to correct speedo. GVW does not change. Tow rating increases considerently. it appears the door jam stickers do not require changing. Dealer will perform gear change soon will see how it works out. Had first road trip on 373s best vehicle I have ever driven.
Old Jun 19, 2017 | 12:12 PM
Ron94150's Avatar
Ron94150
Originally Posted by Campout
My conclusion... it appears the door jam stickers do not require changing.
I'm sure that's what your dealer has told you, I'm not sure I agree with that. It's your choice to except it, and there will probably never be anything to come of it. Yes, the computer needs to be flashed for the gears. This only corrects your shift points. When I went to 4.88's, I drove for a few days without the reflash, and the truck didn't want to down shift when slowing for a turn.
I don't know what package you ordered on your truck, but take it as an opinion from someone that's running 4.88's and 37's, and who's dad has a 4.30 truck with little factory 245/75r17(31.5"), if you ordered a truck with 20" wheels, or have plans on running an oversized tire, skip the 4.30's and go for a 4.56. Especially since your going to be towing heavy. If you ordered a small tire truck, then you should be very happy with the 4.30's. Good luck, and no matter what you do, you will enjoy the lower gear ratio more.
Old Jun 19, 2017 | 07:14 PM
Campout's Avatar
Campout
Wrong gears
Camp out
2017 f350 275/70/r 18 11500gvw srw 6.2 will have 430 gears will start with 9 ft camper and atv trailer possibly 34 ft toy hauler latter. Plan on staying with factory size tires. Use rhino for off road.
Old Jun 19, 2017 | 07:21 PM
RainDesert's Avatar
RainDesert
Camp out
That's a great tire size for the 4.30. My next tires I will be dropping down a bit to the 295/70/18 Michelin which I also feel are a great match.
Old Jun 19, 2017 | 07:57 PM
Ron94150's Avatar
Ron94150
I agree, that's a 33" tire and will work well with the 4.30. I also didn't consider that the ford dealer is doing the work and you probably couldn't get them to install Yukon gears anyway. Enjoy your truck, you will definitely notice the difference in gearing. The truck will want to pull away from red lights effortlessly and will not want to down shift on the small grades.
Old Jun 24, 2017 | 07:16 AM
spud57's Avatar
spud57
Campout
Speedo does not need to be corrected for gear change. Only tire change.
The door sticker does state the rear gear ratio. If the truck gets a second owner, how are they to know the correct gears? What if he needs to repair/replace either the front or rear gears? That could be disastrous thinking they are 373s.
Old Jun 24, 2017 | 09:15 AM
  #28
Ron94150's Avatar
Ron94150
Spud, you are 100% correct on the speedo, and for clarification on your post, and my earlier post for future readers, gear swaps do not effect the speedo. Just tire size changes. BUT, it is important to have the computer reflashed for BOTH! Gear ratio changes do effect the transmission and shift points. Speed is measured off of the tone ring, which speed is only effected by tire size and not gear ratio. Your right about the tag, but it's no different than me or anyone else that's done a regear.
Old Jun 27, 2017 | 01:35 PM
  #29
crewzer's Avatar
crewzer
Exclamation
Speedo does not need to be corrected for gear change. Only tire change...
My take is that the truck must be reprogrammed if the gear ratio and/or tire size is changed.
ref: Bulletin Q-262
HTH,
Jim / crewzer
Old Jun 27, 2017 | 04:42 PM
  #30
spud57's Avatar
spud57
ref: Bulletin Q-262
HTH,
Jim / crewzer
My post was to make the point the speedo does not need to be corrected for gear change. Speedo needs to be corrected for tire size change.
