Sponsored by: Real Truck
Idle problem?
Old Sep 4, 2003 | 03:26 PM
viper69's Avatar
viper69
Idle problem?
Today my new 2003 F250 SD started to have idle problems. When in drive and stopped it idles terrible and acts like it wants to stall. Even in park it idles bad. Sounds like it missing and there is a strong smell of exhaust while this is happening. I stopped at my mechanic before taking it to the dealer. He was not sure what it may be. I did hit a large build up of water in the road pretty hard and it shot water up under the front end and into the engine. Could something just be wet? This only started after the water incident. I only drove the vehicle another 15 miles since and am now at work. Any thoughts may help.....
Old Sep 4, 2003 | 04:51 PM
RRMike's Avatar
RRMike
Idle problem?
What kind of vehicle? Which engine more specifically?
Old Sep 4, 2003 | 05:57 PM
krane operator's Avatar
krane operator
Idle problem?
engine? year?
Old Sep 4, 2003 | 06:24 PM
99f350sd's Avatar
99f350sd
Idle problem?
Water and spark plug wires don't mix well....Can't say unless we know whatcha drive
Old Sep 4, 2003 | 07:31 PM
viper69's Avatar
viper69
Idle problem?
Sorry, Its a 2003 regular cab 4x4 SD 5.4 auto..
Old Sep 4, 2003 | 07:37 PM
nothingbutford's Avatar
nothingbutford
Idle problem?
Is your engine light on? It could possibly be the IAC (idle air control) sensor/valve is bad. Just some thoughts.
Old Sep 4, 2003 | 08:20 PM
FortyFords's Avatar
FortyFords
Idle problem?
Problably water as said ,it tends to short the coils on top of the plugs out .
usually you get and engine chk light ,because of misfires . wonder why you didn't ?????
Let us know what you find!
Rich
Old Sep 4, 2003 | 08:52 PM
haroutd's Avatar
haroutd
From: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
Idle problem?
I'm curious on the water problem being diagnosed here. I remember reading some threads where guys said they wash their engines by spraying with simple green or soap & taking a hose to them. Everyone swore up & down that if the engine was cool, no problems would result. Should I read this to mean that washing your engine this way is not safe? Or is it because his engine was hot & running when he splashed it?
Old Sep 4, 2003 | 08:57 PM
viper69's Avatar
viper69
Idle problem?
The check engine light still has not come on. I tried to idle the truck for awhile while here at work. It seems to be getting a little better. I will be driving home 15 miles and then back again 15 miles tomorrow. If this doesnt fix it I guess its off to the dealer. I was told never to directly wash my engine because of all the computer and senser items nowadays. Thanks for the imput...
Old Sep 4, 2003 | 09:01 PM
nafzimo's Avatar
nafzimo
Idle problem?
You got plug wires?
Old Sep 5, 2003 | 01:05 PM
viper69's Avatar
viper69
Idle problem?
Well on the way home last night the check engine light did come on and its still running terrible. Its off to the dealer on Monday...
Old Sep 9, 2003 | 08:12 PM
viper69's Avatar
viper69
Idle problem?
I got my answer from Ford today. They said I had a bad injector. They are replacing it. I guess it wasn't the water problem as I thought.
