Line-X bedliner question
#61
I got the premium level with a color match to the King Ranch Caribou color, only had it a couple of months and like it a lot. Previous truck had liner put in by the dealership that was "just as good", it was fading in less than two years. NEXT previous truck had a Line-X which looked good for more than five years.
#62
We had one truck with the Ford factory sprayed bed. Like you we had it done as part of ordering a 5th wheel setup. Because of the hardware in the bed, it doesn't get the abuse that a flat bed would in our hands, but it still gouged and had localized wear faster than LineX. We had a 1200 mile drive with a large trailer on the 5th wheel and had a 160 lb steel tool chest sitting in the back. It slid around a bit -- perhaps six inches or so -- constrained by a couple straps to the sidewall of the box. After 1200 miles of highway driving, it had rubbed through the factory spray in the corners. Now when we have it on a trip like that we always put a piece of 3/4" ply under it to protect the liner. Subjectively, the LineX feels tougher, and it seems to be more resistant to a utility knife than is the Ford. Also, we've seen trucks delivered both with the spray liner stopping at the bed hardware and other factory jobs where the bed got sprayed before the hitch hardware was installed. We had to take our hardware off on one occasion and we had a big square of bare metal in the center of the bed. It was not cool. And these were both factory installs (definitely not dealer jobs) so Ford seems to be a little inconsistent about how they do it. Again, a reason to use Linex and do it right.
#63
question. Is the Line-X significantly tougher than the factory sprayed bed? I plan on a Bakflip cover and a 5th wheel/gooseneck prep so it sounded less complicated than doing it later and worry about the bed bolts etc. But if Line-X was significantly tougher, I might reconsider.
#65
I had my liner done last week. I went with the Premium. Felt it would suit my needs just fine.
I was very reluctant about having them remove the bed bolts and spray under them. I was assured they do it on every truck and it would be fine.
Against my gut feeling, I went ahead and let them remove the bolts.
When I picked up the truck, I noticed the bed was not even and lining up with the cab the same on both sides. It may have been like that from the factory and I never noticed. However, now I was specifically looking for it and noticed it.
So yesterday, I decided to try an adjust my bed. I loosened the bolts, but when I got to the driver side 2nd bolt back (the one right above the fuel tank), it just spun.
After investigating, discovered the bolt was not threaded into anything!
Dammit. They managed to dislodge the clip nut and not bother to try and put it back.
Of course this is right above the fuel tank. With luck, I found the clip on top of the fuel tank. It has been up there for about 500 miles.
I struggled contorting myself into a pretzel, but with my dad's help and a lot of luck, I was able to get the clip back in and get the bolt to thread.
I was unable to shift the bed, but did get the bolts torqued down appropriately.
So, to anyone else debating about having the bolts removed to have the liner sprayed in, I would think long and hard about it. If I were to do it again, I would not
#66
#68
I went into the LineX dealer and firmly said that I wanted the more expensive premium (black color)....to my surprise, he talked me out of the it. He was willing to do the premium if I wanted it. He said the only thing the premium has over the standard is the UV protection -- other than that, they are the same.
After a period of years, the standard will loose it's shine, but the bed protection is the same---your just paying more for the shine.
Frankly, I normally keep a tonneau cover over mine, so it doesn't get much UV.....and the inside of the pickup bed being super shiny is not important to me.
#69
Matt
#70
Had my truck sprayed in February. I wanted them to spray over bolts, they said it will look terrible, be hard to remove bolts it needed someday, etc. Then I told them that I heard these bolts are 'single use' and they said no they're not....they are the same as the F150.
I noticed a popping noise when truck would articulate at slow speeds. Dealer visit #1: they tightened suspension down and couldn't replicate the problem. Dealer visit #2: I suggested that it could be the bed bolts. They agreed and didn't have them in stock. Dealer visit #3 (today): all bed bolts were replaced (4 we're toast). I was told that all must be replaced even if there is an issue with one. Anyway, problem solved....
Moral of the story: Don't touch the bolts, spray over them.
#71
i agree, but the shop is 100 miles away from me. it's one of those things, i could fix my self and be done with it.
how were the bolts "toast"?
I don't see how a grade 10.9 bolt can be a "single use" bolt
i bet your bolts were not torqued down properly after they sprayed the liner. i know my were not
#72
i bet your bolts were not torqued down properly after they sprayed the liner. i know my were not[/QUOTE]
Maybe they weren't torqued properly after the spray. But the dealer tried torquing them properly on visit 2 and it didn't work. Mechanic said they were 'toast' I don't know what that means but he also said they are 'single use'. I'm grateful that they handled this as a warranty item.
#73
