readhead steering boxes
Old Jun 14, 2017 | 08:51 PM
mcali2's Avatar
mcali2
Well the new box and all the new tie rods did not change anything I can see. The shop said the truck is as good as a 30 yo truck can get. there was slop in the steering when they were new. I told them people say the redhead removes the slop. he seems to think the rebuilt boxes have alll new parts and I say the gear that the ball runs through is not new and just reused. The redhead uses different ***** to remove the slop. Am I wrong?
Old Jun 14, 2017 | 09:00 PM
knottyrope's Avatar
knottyrope
Some say they use a different shaft that takes out some slop.
I never had one apart to know but keep reading on how many love them
Old Jun 15, 2017 | 07:55 AM
madpogue's Avatar
madpogue
^^^^ +1; rag joint in the OEM shaft is an obvious source of slop.
Old Jun 15, 2017 | 08:47 AM
mcali2's Avatar
mcali2
Not the rag joint on my truck. its tight as can bee, The shop even tested the shaft.
Old Jun 16, 2017 | 09:25 AM
Bill97's Avatar
Bill97
I'd like to subscribe to this thread. My truck is terrible too, so I'm thinking of just starting to replace all the steering components a little at a time. I did tie rods, drag link, and tightened all the bolts I could find and I still have 5 inches of dead wheel, and the truck tracks poorly. As you said, no good when you have a trailer behind you. You would think if the steering box is new, and the shaft is tight, that should at least address the dead space in the wheel.
Old Jun 16, 2017 | 09:35 AM
mcali2's Avatar
mcali2
Something i learned yesterday talking to a rep at redhead is the box has to be centered or there will always be slop. the adjustments to remove slop are all made at the center point, anything off center will have play. We just don't feel it as we are turning. mine turns about 1/8 a turn or about 6'' more to one side. I don't know if that makes any difference. The truck came back from the shop with about 1 inch of play now.
Old Jun 16, 2017 | 09:57 AM
Bill97's Avatar
Bill97
Sounds like a nice improvement! Thats good to know.
Old Jun 16, 2017 | 08:42 PM
z31freakify's Avatar
z31freakify
You can always adjust your steering box, most alignment shops don't do this because if you over do it your trucks tires will track and become really dangerous, you can adjust it by turning the adjuster Allen screw 1/4 of a turn drive and do drive it and adjust till you get the slop out.
Old Jun 16, 2017 | 10:59 PM
nateairman's Avatar
nateairman
I have heard that you can adjust the play out of the center but be sure to test it lock to lock where you will not crash if it gets stuck.
Old Jun 19, 2017 | 11:15 AM
mcali2's Avatar
mcali2
I have don't that in the past and all it did was make it tight to turn and the play was the same. I'm going to live with it for now.
Old Jun 20, 2017 | 02:33 AM
fajitamondays's Avatar
fajitamondays
I have a '96 F250 with over 330K miles that had steering almost worse than a '67 Mustang a family member of mine has. I had to keep the steering wheel on the truck at about the 1 o'clock position to keep it going straight, had serious slop, and had a really neat tendency to randomly wander in long sweeping turns on the freeway. I replaced the box with a Redhead, and it has been wonderful since. Brought a smile to my face on the very first turn I made after I installed it. Money well spent.
The Redhead shop is only about 25 mins from my place, so I paid them a visit when I went to pick mine up. They seem like a good outfit.
Old Jun 20, 2017 | 03:25 AM
Kingkong0192's Avatar
Kingkong0192
How much are these redhead boxes? My steering also has about an inch to two of dead space but I've grown used to it.
Also I never really directly looked but I feel like my 97 doesn't have a rag joint. I feel I would of noticed it if it did. What years had them?
Old Jun 20, 2017 | 06:50 AM
  #28
Jarrett Campbell's Avatar
Jarrett Campbell
Mine has one. I *think* the only way you don't have one is if someone went in and replaced it with a u joint or something.
The joint is under a little plastic cover just above the steering box. I bet you just never lifted that plastic cover to see it.
Old Jun 20, 2017 | 10:01 AM
  #29
78 PEB's Avatar
78 PEB
Google Readhead steering.....they have a website with application and prices.......
Old Jun 20, 2017 | 10:31 AM
  #30
knottyrope's Avatar
knottyrope
https://www.redheadsteeringgears.com...olt-top-cover/
$266 for a nice tight box might be worth it
