Sponsored by: Real Truck
2001 v 10 is missing
Old Jun 10, 2017 | 01:30 PM
moosenbabe's Avatar
moosenbabe
7th Gear
No, I know where it is.. it's not running right. It acts like there is water in the fuel. No check engine light. Put it on computer is 2 different garages, nothing shows. New plugs, coil packs, fuel pump.. and the list goes on. Started doing it at about 90,000 miles. Any ideas? I will entertain any ideas at this point!!
Old Jun 10, 2017 | 01:34 PM
alloro's Avatar
alloro
Crankshaft position sensor?
Old Jun 10, 2017 | 01:36 PM
moosenbabe's Avatar
moosenbabe
7th Gear
Did the cam.. not crank yet. Might be my next move.
Old Jun 10, 2017 | 06:47 PM
moosenbabe's Avatar
moosenbabe
7th Gear
Anyone think it might be an injector?
Old Jun 10, 2017 | 06:58 PM
Chuck's First Ford's Avatar
Chuck's First Ford
a injector problem.. stay-ing open to long.. black spark plug.. not opening.. a misfire and the computer will report it. same if not opening as long as expected (lean).
Low fuel pressure can cause issues.
go to a shop with a portable OBD(I) II computer.. they can go for a test drive and read Real Time data...
they can SEE if injectors.. plugs firing. timing, fuel pressures, ALL sensors working.
not just Stored faults..
Old Jun 11, 2017 | 08:33 AM
moosenbabe's Avatar
moosenbabe
7th Gear
Thanks for the info!
Old Jun 11, 2017 | 08:38 AM
moosenbabe's Avatar
moosenbabe
7th Gear
One other question besides what is making it miss. Does anyone think it could be the computer? I have had computer problems in other vehicles.. seems like a reoccurring theme with me.. lol. Wondering what you all think. Thanks.
Old Jun 11, 2017 | 04:42 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by moosenbabe
... Put it on computer is 2 different garages, nothing shows. ...
Did the garage computers have the capability to monitor Mode 6 data for misfires or just look for codes?
You can have a lot of misfires before a code is actually set, especially if it's 2 cylinders.
You can get an OBDII port bluetooth adapter for under $25 and software like Torque Pro $4.99 (Google) to see the data.
If you can narrow things down to 1 or 2 cylinders it will be much easier to figure things out.
Did you check the IAC valve, make sure no air leaks in the intake tube, check the throttle body down past the butterfly?
You indicated the fuel pump was changed.
How about the fuel pump relay or filter?
What is the fuel pressure?
Scwindle6586
May 28, 2020 06:13 AM
Laydbak1
Modular V10 (6.8l)
27
Nov 19, 2018 06:43 AM
kimberlator
Jun 18, 2008 10:37 PM
rosebud1959
Apr 30, 2007 07:04 PM
jeff_anderson
1997 - 2003 F150
23
May 5, 2005 12:06 AM
