Old, old, old CL posts
Old Apr 21, 2017 | 07:44 PM
gapman789's Avatar
gapman789
'02 XLT, 4x4, v10, 116k miles, $8900. Ohio
Worthington Preowned Vehicles for Sale
Old Apr 22, 2017 | 10:26 AM
Apocalypse's Avatar
Apocalypse
Old Apr 23, 2017 | 09:30 PM
gots_a_sol's Avatar
gots_a_sol
Cheap Ex that needs some work
https://richmond.craigslist.org/pts/6099109385.html
2001 FORD EXCURSION
6.8L V-10 motor 204K runs great
4X4 transmission works great
A/C works good front and rear
Tan interior is ok
No radio
#7/17 inspection
Some rust on quarter panels
Bearing on power steering pump is going bad makes noise but still works.
Needs 1 tire but also have good spare
$2000
8042181482calltxt
Old Apr 23, 2017 | 09:32 PM
gots_a_sol's Avatar
gots_a_sol
V10 headers
https://reading.craigslist.org/pts/6094243853.html
brand new! stainless steel exhaust headers will fit truck,excursion,motor home but not van. Were 772.00 new, direct replacement of exhaust manifolds will bolt to stock Y pipe I'm heading to Carlise if you want them there.
Old Apr 23, 2017 | 09:34 PM
gots_a_sol's Avatar
gots_a_sol
Old Apr 23, 2017 | 09:36 PM
gots_a_sol's Avatar
gots_a_sol
Old Apr 23, 2017 | 10:02 PM
DidieX's Avatar
DidieX
Originally Posted by gots_a_sol
V10 headers
Brand new! stainless steel exhaust headers will fit truck,excursion,motor home but not van. Were 772.00 new, direct replacement of exhaust manifolds will bolt to stock Y pipe I'm heading to Carlise if you want them there.
I would take those if they are a reputable brand and not cheap eBay stuff.
Old Apr 24, 2017 | 08:05 AM
DidieX's Avatar
DidieX
V10 headers
Is anybody near here that can grab these for me until I can drive down and pick them up, maybe Sunday? TIA.
Old Apr 24, 2017 | 12:53 PM
Apocalypse's Avatar
Apocalypse
Personally I would skip those. There is a reason they never installed them, think about that. If you're going to go through all the work of replacing the headers at least make sure you're doing it with the best parts available. Go with the Banks kit like a few of us have, it'll last you forever.
Old Apr 24, 2017 | 03:24 PM
andy9743's Avatar
andy9743
I disagree. the banks kit is 5 times as expensive. I'd pick them up if I was local and wouldn't be afraid to install. there's plenty of reasons why they may not have been installed...the install sucks. are the banks 5 times better? I doubt it.
that said I have the banks kit. its just super expensive. if these were an option when I was looking for a deal I would have jumped on them..my 2 cents.
Old Apr 24, 2017 | 03:31 PM
DidieX's Avatar
DidieX
I was about to say exactly that. Can't afford the banks and I need to do something as my existing ones are leaking bad and most of the studs are cracked. Already contacted the guy, trying to figure out how to pick them up/ meet up.
Old Apr 24, 2017 | 05:30 PM
RobRoss's Avatar
RobRoss
The potential downside is you still retain the factory Y pipe. If your goal is to only repair the leaks then it may be a good value for you...or take the opprptunity to improve the Y pipe while you're changing to headers. I haven't looked to see if they are available but Remflex is a very good header gasket. Just be sure to retighteb after several heat cycles.
Old Apr 24, 2017 | 05:49 PM
  #28
WE3ZS's Avatar
WE3ZS
When you contacted the seller did he provide any additional info such as the manufacturer (I can see a plate on one tube but can't blow up the image enough to read it) or if there is a Y pipe in the kit. They look like shorties from the pic, just not sure what all comes with....
Old Apr 24, 2017 | 05:52 PM
  #29
Apocalypse's Avatar
Apocalypse
I don't know, I would just save up for the banks. After trying to do it on the cheap it didn't work out and I spent more than if I had just done it right the first time. Someone gifted me a used set that needed to be fixed. I sent them to a member on here that welds and he fixed them. I installed them and they still leaked. I spent about $150 on shipping and parts to fix them and in the end I scrapped them for $0.25 at the local yard (along with a few hundred pounds of other metal). Had I just bought ones with no history I would have saved weeks of work and tons of money.
Old Apr 24, 2017 | 06:07 PM
  #30
05MilMachine's Avatar
05MilMachine
I see the letter TS FAST or T5 FAST. Google turns up nothing for either. I'm guessing they are eBay headers. It's a gamble either way but provided they are installed properly, they should be OK.
