crazy oil pressure
Old Sep 4, 2003 | 10:56 AM
jwdenney2's Avatar
jwdenney2
crazy oil pressure
I recently submitted a thread about my oil presure gauge fluttering. It reads low sometimes and occasionally comes back up when I turn the A/C or the lights on. I tested the gauge and have replaced the sender. Someone said I have a loose wire somewhere that is causing the change in signal with a change in voltage.
Where should I be looking for this loose wire? Has anyone else had this same problem and been able to find the wire/fix the problem?
Thanks in advance for your help.
