2000 Expedition - Replace Rear Door Lock Actuator - Help Needed
Old Jun 5, 2017 | 06:52 PM
kailor's Avatar
kailor
Hello all. It's been a LOOOONG time since I last posted. I'm trying to replace the rear driver side door lock actuator on my 2000 Expedition. I've drilled out a rivet on the outside of the door to free the actuator from the door body. I have removed the latch mechanism (3 torx screws). I just cannot determine how to get the linkage off so that I may remove the actuator from inside the door. I see yellow things and a green thing...Any and all suggestions/information to help me accomplish this would be very much appreciated. Tips on putting the new one in would be great, too. I can then apply said knowledge to do the other rear door, too. Thanks in advance. Keith.
Old Jun 6, 2017 | 08:18 AM
alloro's Avatar
alloro
Here is the procedure.
File Type: pdf
Old Jun 6, 2017 | 02:02 PM
kailor's Avatar
kailor
Thanks Alloro. Exactly what I needed. What size and kind of rivet should be used?
Old Jun 7, 2017 | 09:27 AM
alloro's Avatar
alloro
Depends on the size of the hole it's going into. You'll have to measure it or use nuts and flat head bolts.
Old Jun 7, 2017 | 08:09 PM
kailor's Avatar
kailor
Replaced both rear door lock actuators. All are working perfectly now.
Old May 27, 2019 | 08:15 PM
F-22's Avatar
F-22
Alloro do you have the workshop manual section for the rear hatch / liftgate lock actuator replacement? Please post it if you do.
I have 1997 Expedition.
Old May 28, 2019 | 04:23 AM
alloro's Avatar
alloro
I posted it in the other thread where you requested it.
https://www.ford-trucks.com/forums/1...l#post18675901
Old May 28, 2019 | 10:17 AM
F-22's Avatar
F-22
Sorry for the duplicate posts.
Thank you for the workshop manual files!
tx_armadillo
May 28, 2019 10:14 AM
kamloops
Michigan Chapter
Apr 20, 2008 08:31 AM
bence5555
Sep 13, 2005 03:31 PM
