Sponsored by: Real Truck
2012 f250
Old Jun 5, 2017 | 10:52 AM
maineguy53's Avatar
maineguy53
2012 f250
My dome light isn't working when open the door . checked fuse #4 and 12 in fuse box any ideas?
Old Jun 5, 2017 | 12:31 PM
seville009's Avatar
seville009
Check the bulb
Old Jun 5, 2017 | 02:46 PM
Chuck's First Ford's Avatar
Chuck's First Ford
easy first .. BULB..... then door light switch. built into handle lock. I think...
Old Jun 5, 2017 | 05:38 PM
maineguy53's Avatar
maineguy53
I push the bulbs on by hand and they work so bulbs are good
Old Jun 5, 2017 | 05:42 PM
maineguy53's Avatar
maineguy53
door light switch . built into handle lock not sure what that is. this truck is fully loaded with all the options possible so it might be
Old Jun 6, 2017 | 06:34 AM
Chuck's First Ford
so you are saying if you PRESS on bulb it LIGHTS????
then the light socket might be BAD. or dampness has damaged the bulb or socket.
Old Jun 7, 2017 | 05:41 AM
Brettb1's Avatar
Brettb1
I'm having the same problem. The two front will come on when turned on manual. the rear has a new bulb. the dimmer switch on the dash will not turn them on and they do not come on when the doors are opened. fuses are good.
Old Jun 7, 2017 | 07:41 AM
Ron94150's Avatar
Ron94150
Do they come on when the passengers side door is opened? Also to the OP, did you check the fuses or just pull them out and look at them to see if they looked blown.
Old Jun 7, 2017 | 10:17 AM
Brettb1's Avatar
Brettb1
I checked them with a test light
don't work with any door
Old Jun 7, 2017 | 10:52 AM
89LX306's Avatar
89LX306
Isn't there something like a police dark mode for these trucks? Could that be turned on?
Old Jun 7, 2017 | 08:28 PM
NHBILL's Avatar
NHBILL
Does the dash indicate door ajar if you turn the key on with the door open?
Old Jun 8, 2017 | 05:38 AM
Brettb1's Avatar
Brettb1
Yes it does.
Old Jun 11, 2017 | 05:59 AM
maineguy53's Avatar
maineguy53
yes my door ajar lights up also fuses all good
Old Jun 12, 2017 | 09:10 AM
maineguy53's Avatar
maineguy53
Have our truck going into the ford garage Wednesday to check out why dome light doesn't work
Old Jun 15, 2017 | 06:30 AM
maineguy53's Avatar
maineguy53
had the dome light check and ford said its the module that goes with the fuse box
