hitch wear - normal?
Is this normal or excessive for one year's worth of use?
I'll be honest, I haven't been greasing this area. I live on gravel and i was afraid the grease would attract dust and do more harm than good. I did grease them this time with some spray grease which seems to clean up easy, but I'm wondering if that is good enough.
The bottom doesn't look deformed but you cam see some wear. The bars look pretty good without discernible wear, just "shined up"
Thoughts?
Top of trunion
Top of trunion
Another angle
Overall, a little dab or grease, and don't worry too much.
my only reservation with greasing it has been that i'll have to wipe the grease completely off of everything every time I use it. that is to say when I get where I'm going it will be covered in dust from the drive out, and when I get home it will be covered from the drive home. so i'll have this nasty greasy rag I've got to deal with 4 times at every trip.
maybe that's the way it is and I need to just plan for it and deal with it, but that's why I've been leaving it dry.
it is looking more and more like I need to "just deal with it" and keep it greased. I agree, the pics don't look good, which is why I posted the question - it is concerning. looks like it is prematurely wearing.
the way the metal is distorted it almost looks like I'm putting too much force on the head, but I'm using the 1200 lbs bars for a tongue weight that is just bit over the 800lbs mark when I last measured. (I should try and measure it again, or take it to the scales).
if only they could make a grease that didn't attract dust!
I'm thinking I might take a old bath towel and cut it up into smaller squares and keep them in a tub by the hitch. that way I can have a supply of grease rags I can just throw away rather than trying to keep a greasy rag to use for the next time. it doesn't take much to wipe it clean, but it was always the problem of "what do you do with the greasy rag, and if I throw it away what will I use next time"
I've always wiped them clean with a rag because of the dust, just not with grease.
just one more thing to remember and do, I guess.
Less noise and wear.
we camped about 6 times, and every time we leave we are in a hurry or the kids are not going to tolerate the wait for me to dump, so I haul it home with the holding takes full and take it to the park close to home to use the dump station. so there is at least 12 hook-up's with camping. then there were a few more to do other random stuff.
I doubt there is 500 miles on the hitch, though, a fair bit of maneuvering, in those miles.
I do find it concerning....
https://www.etrailer.com/question-10420.html
I pull a 33 ft. 8,000lb. double slide TT with a Toyota Sequoia. I purchased a 1200lb Straightline from you in 2007 and it has about 30k miles on it. The receiver for the trunions has worn quite oval. The trunion pin ends are worn but not terrible. The cams and friction parts just show what I would call normal wear. My concern is if the receiver socket wears too thin, breaks and the trunion bar goes flying. Are there any guidelines for thickness of the receiver? Thanks!
asked by: Jeff K
Expert Reply:
I spoke with my contact at Cequent, the manufacturer, and he stated that there is no specification on the thickness of the socket. We talked about the wear on your RP66074 WD system and he stated that 30k miles was quite a lot and some wear was to be expected. This wear could be made worse if the system is not properly and routinely cleaned and lubricated.
It seems to me that if you are even remotely concerned about the system failing in any way, then it is probably time for some replacement parts. We offer the Replacement Trunnion and Pin, # 58097, if you think the wear on them is bad enough. You would need a total of two.
But the bigger issue seems to be the head. To replace it, you will need the Replacement Weight Distribution Trunnion Style Head, # RP58167. If you replace these parts and keep the system cleaned and lubricated, it will solve the problem. Make sure you clean and replace the grease frequently. What happens is dirt and road grime get into the system and it acts like sand, slowly grinding away at the components. If you need grease, I recommend Trailer Hitch Grease, # L10337. I have also included the instructions for RP66074 below.
You will need to double check that the vehicle, hitch, and all the components you use to tow, are rated for towing a 33 foot, 8,000 pound trailer.
