Factory turbo timer/auto shutdown. Can I add it?
Old May 25, 2019 | 10:47 PM
Rockinfigs's Avatar
Rockinfigs
Originally Posted by mhoefer
If you deselect the option above, when you exit the vehicle, lock it, walk away with your fob in your pocket, the truck will shut off, amd you won't get the double honk. With it set to check this off it will let you leave the vehicle running amd leave, you will get a double honk, but it will let it idle. Then just shut off with the remote or let it idle.
How do u shut off the engine using the remote?
Old May 26, 2019 | 10:51 AM
f350ktm's Avatar
f350ktm
Push the 2X button once more
Old May 27, 2019 | 01:04 PM
mhoefer's Avatar
mhoefer
Yes, you can shut off the truck when on remote start only. Double press the start button and it shuts off sends a red light signal to the remote. I have learned this all using Forscan, as I have Police mode engaged such that if I leave the truck running and get out, it cant be taken out of park. I have secure mode left operational so I can leave the vehicle running without the horn honk. I have police mode on so if I do leave it running the kids cant accidentally get it out of park and cause an accident. For turbo timer, I would do the same thing, exit the vehicle after shutting off and then shut off after idling for 5 - 10 minutes using the remote.
milkweed.gardener
May 26, 2022 07:35 AM
Flyct
6.7L Power Stroke Diesel
Dec 25, 2017 01:07 AM
HS400
Mar 16, 2009 09:29 PM
fordsd350
6.4L Power Stroke Diesel
Feb 12, 2009 07:19 PM
Gwar
Mar 24, 2006 09:28 PM
