Locking 3" Hitch Pin?
Old Jun 3, 2017 | 10:48 PM
ToUtahNow's Avatar
ToUtahNow
I am currently using a 5/8" Bolt Locking Hitch Pin.
https://www.boltlock.com/shop/58-receiver-lock/7023585/
I like it because the key in the fob is programmed to unlock it. I don't line it because it's not long enough for comfort and I'd rather have a 3/4" hitch pin. In the two months since I bought the truck I've put 7,000 towing miles on it. Still in the back of my mind, I feel it is the weak link. I'm wondering what others are using?
Mark
Old Jun 4, 2017 | 07:38 AM
Uzumati's Avatar
Uzumati
What are you dragging around? 5/8" pin is rated to 10k. I am using a master lock pin lock on mine and never think twice about it but if I'm pulling over about 4k then it is going on the gooseneck
Old Jun 4, 2017 | 09:14 AM
k7lvo's Avatar
k7lvo
I'm still waiting for my truck, so this the first that I've thought about this.
Does the 3" receiver have a 3/4" hole? I'm not sure that I'd want an eighth of an inch of slop. I would thin that it would put noticeable stress on the pin, and probable extra wear on the hole in the receiver. On top of that, if the 2" stinger only has a 5/8" hole, what do you do then? Use the 5/8" pin an put bushings in the 3/4" receiver?
Old Jun 4, 2017 | 09:19 AM
ToUtahNow's Avatar
ToUtahNow
Everything from a 12' single axle utility trailer to a 30' triple axle equipment trailer with a Case 70+4 articulating trencher with a front hoe and rear blade and a lot in between..
Mark
Old Jun 4, 2017 | 09:37 AM
ToUtahNow's Avatar
ToUtahNow
Yes the 3" receiver has a hole for a 3/4" pin. Most hitch locks are rated for 2" or 2" plus 2 1/2" hitches.
I lost a hitch pin somehow once while pulling a boat at 70 mph and it wasn't fun. Fortunately having good safety chains and the trailer staying attached to the ball on the hitch it turned the hitch into a ski.
All I can figure out was my cotter pin either broke or someone stoles it at a gas stop.There is nothing like seeing you boat trying to pass your Class A on the right to wake up your survival skills.
Mark
Old Jun 4, 2017 | 10:03 AM
bushpilot's Avatar
bushpilot
https://www.ford-trucks.com/forums/1...r-inserts.html
Old Jun 4, 2017 | 11:27 AM
1956Fatfenders's Avatar
1956Fatfenders
Not having a 3" receiver on mine (I have the "lowly" 2.5"), wouldn't this work? It shows a 3.55" bolt length.
https://www.boltlock.com/product-spe...pecifications/
Old Jun 4, 2017 | 01:00 PM
gpf2ez's Avatar
gpf2ez
https://www.weigh-safe.com/product/hitch-locking-pin/
I bought one for my Weigh Safe Hitch but it will work with any hitch. I think you need to tell them you want the one for the 3' when ordering.
Old Jun 4, 2017 | 01:53 PM
ToUtahNow's Avatar
ToUtahNow
That is the one I am using now and while I like it it is just barely long enough by about .05" plus I'd like a 3/4" pin. I'm planning another 1,000 miles starting tomorrow.
Mark
Old Jun 4, 2017 | 05:13 PM
FOURBYBUD's Avatar
FOURBYBUD
Now I'm really confused..lol. I've got the 3in receiver hitch with a standard 5/8in hole..
Old Jun 4, 2017 | 05:28 PM
onetwothree's Avatar
onetwothree
this works for me (2017 F250 ccsb platinum)
Amazon Amazon
Old Jun 4, 2017 | 06:46 PM
gary 5th wheel's Avatar
gary 5th wheel
I'm confused as well. I have a 350 SRW which came with the 3 inch receiver but only a standard 5/8 inch pin.
Old Jun 5, 2017 | 01:07 AM
prime81's Avatar
prime81
Here ya go... it barely fits but it's solid.
https://www.lowes.com/pd/Reese-Class...r-Lock/3824611
Old Jan 10, 2018 | 10:00 PM
Fr8dog69's Avatar
Fr8dog69
My 17 F-350 dually diesel has a 3” receiver with a 5/8” pin that ford has stamped 21,000 lbs on. Bought a locking Trimax 5/8” pin that says exceeds 40,000 lbs.
Old Jan 11, 2018 | 06:17 AM
marobrown's Avatar
marobrown
I took my factory pin to work and drilled the cotter pin hole out larger to accept a padlock. Never used a locking hitch pin but I pull my hitch out when I’m not towing. Working at a tool rental yard while I was in college I took a torch to at least half the the locking hitch pins that came in on trucks because they were never removed and seized on and would not come off.
