No power - Distributor issue ???
Old Jun 2, 2017 | 11:22 AM
Migs7's Avatar
Migs7
Yo!
So ive been having an issue with my 87 F150 4.9/300 EFI... I have no power underload/uphill.
Looking for possible solutions to the power issue i noticed that the distributor/wires are setup as you can see in picture 1 below. Funny thing is my Ford Shop Manual, Haynes Manual, and my AllDataDiy account show pictures that say it should be setup the way its shown in picture 2 below.
What is the correct way to install this ? Any help?
the truck is givng me around 18 miles to the gallon and hasnt thrown any codes...
Picture1: current set up no power EFI
Picture 2: setup as shown in all of my sources.
Old Jun 2, 2017 | 01:05 PM
joey2fords's Avatar
joey2fords
the set-up that you are using is for 86 and earlier. the 2nd set-up is the one you should follow.
Old Jun 2, 2017 | 01:12 PM
Migs7's Avatar
Migs7
Hey thanks for the response!
so i should be using this one right?
Old Jun 2, 2017 | 01:32 PM
joey2fords's Avatar
joey2fords
sorry ... somehow i got it backwards. you are using the correct set-up for 1987 and later.
Old Jun 2, 2017 | 01:33 PM
White 97 xlt's Avatar
White 97 xlt
If it runs at all you have it "pretty close".... The thing to do now is get out, borrow, or rent a timing light, pull the spout connector and set the timing.... It should set to 10° BTDC, but you can play with it and go up to near 14°, just listen for it to ping under load, if it does back it back down a degree or two until it stops pinging under load.
silverbullet6oh
Jun 6, 2016 01:18 PM
jrf81
Jan 27, 2015 09:22 AM
gt40racing
Sep 28, 2010 10:43 PM
KingSac85
Jul 19, 2003 02:39 PM
