Buzzing noise from under dash
Old Jun 1, 2017 | 06:24 PM
Laggy's Avatar
Laggy
1995 f350 XL. After a month of owning truck, it's making a buzzing under dash when I start the truck. Last 2-3 seconds.
Any ideas? Is this an indicator of some sort or is that a noise the equivalent of "key in ignition" warning chime?
Old Jun 1, 2017 | 07:32 PM
*2fords*'s Avatar
*2fords*
I think it's the seat belt buzzer.
Old Jun 1, 2017 | 07:53 PM
Laggy's Avatar
Laggy
You know what's funny is that it started 2 days ago. Which is when I first decided to use the seat belt. Coincidence?
Old Jun 1, 2017 | 08:11 PM
mrollings53's Avatar
mrollings53
You can remove the buzzer without effecting anything. It won't warn you if you leave the keys in the ignition, or the headlights on though.
Old Jun 2, 2017 | 07:33 PM
*2fords*'s Avatar
*2fords*
You may have scraped some rust off or something when you used your seat belt. Who knows?
Every once in a great while, mine will work for a bit then stop again. I don't even worry about it, these trucks have so many odd gremlins, it'll kill you worrying about why something decides to work then doesn't.
Old Jun 3, 2017 | 01:23 AM
Laggy's Avatar
Laggy
Copy that!!
Old Nov 19, 2017 | 07:52 PM
Jeff Graham's Avatar
Jeff Graham
Constant buzzing sound from under the dash
I just got a 2001 F-350 with the lights switched over to LED.
I have a constant buzzing sound from under the dash. it will keep doing this even though it is not running.
The only thing that shuts it up is using the turn signals.
Any suggestions for fixing it
Old Nov 20, 2017 | 12:09 AM
mrollings53
Ask the guys over in the Superduty forum.
https://www.ford-trucks.com/forums/forum30/
Old Dec 2, 2017 | 02:00 AM
Laggy's Avatar
Laggy
Lol...I see what you did
Old Dec 2, 2017 | 02:01 AM
Laggy's Avatar
Laggy
Chase a bad ground
mustangmatt
Aug 2, 2016 02:55 PM
CPaulsen
May 11, 2011 08:43 AM
GregN
Sep 27, 2010 05:23 PM
Pwned123
Nov 6, 2007 05:52 PM
6overZilla
2004 - 2008 F150
Nov 23, 2005 03:57 PM
