Torklift PowerArmor: Preventing Expensive Battery Theft
Torklift International’s PowerArmor line features high quality locking aluminum battery boxes. With security in mind, each locking battery box was specifically engineered to prevent increasingly common battery theft and related damage to wiring from 'cut and run' thefts. Keep expensive batteries under lock and key with PowerArmor and PowerArmor Solar battery storage boxes.
The PowerArmor battery boxes provide safe lockable storage and are available in multiple box sizes. Enjoy a secure compartment for storing up to five batteries, various gear or other equipment. Box sizes accommodate a multitude of battery types, including both 12 and 6-volt battery applications. The design incorporates a unique lockable slide top (lock included) for quick, easy access, no matter your mounting location. Made from 100% heavy gauge diamond plate aluminum with black high impact powder coat frame, the PowerArmor storage box can bolt directly to your RV, trailer tongue, camper bumper, etc.
When using the PowerArmor to store batteries, you benefit from having extra battery power for your RV, truck camper or vehicle. An access port allows for electrical wires to pass through the side wall of the box so it easily connects to your electrical circuit system. With battery health and performance in mind, the locking battery box features a special ventilated design and acid neutralizing battery mat.
To extend the life of your batteries up to 400% and prevent premature battery replacement, opt for the PowerArmor Solar battery box. With a 10-watt solar panel securely bolted through its lid, solar energy trickle charges the batteries helping keep them in optimum condition year round. Batteries sitting in storage over the offseason may suffer from sulfation (caused by undercharging) which results in permanent negative effects on battery performance. Easily maintain your batteries without overcharging or undercharging, keeping them in great condition, lasting longer and saving you money. Even without direct sunlight, the high quality Zamp solar panel on PowerArmor Solar absorbs reflective light to continually generate charge.
Each PowerArmor locking battery box comes with Torklift International's Legendary Lifetime Warranty and is proudly made in the USA.
PowerArmor Solar in Action
PowerArmor Features
PowerArmor Features
- Prevent common and expensive storage/battery theft (lock included)
- Maintains charge increasing the longevity of the batteries up to 400% to avoid premature battery replacement (solar only)
- Dual use for securing batteries and other gear
- Bolts to your RV, camper bumper, truck, van, etc.
- Heavy gauge diamond plate aluminum for maximum durability
- Designed specifically to access RV batteries avoiding interference with your RV
- Uses a 10 watt solar panel (solar only)
- Comes in bright tread diamond plate featuring black high impact powder coat frame
- Multiple box sizes available holding up to five batteries
- Adjustable dividers for custom size compartment storage (PowerArmor Max only)
- Acid neutralizing battery mat to avoid corrosion
- Legendary Lifetime Warranty
- Proudly made in the USA
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
01-29-2019 01:09 PM
Torklift Sheryl
10-18-2018 04:56 PM
Torklift Sheryl
08-01-2017 04:32 PM
Torklift Sheryl
07-24-2015 10:24 AM
Torklift Sheryl
03-12-2015 11:17 AM
