fan size??
Old Sep 3, 2003 | 10:35 PM
Screamin T/A's Avatar
Screamin T/A
fan size??
I'm looking to buy a flex fan for my truck. It has a 351m in it. I was wondering what size fan I should buy and whether or not it is reverse rotation. thanks
Old Sep 3, 2003 | 11:29 PM
Torque1st's Avatar
Torque1st
Posting Legend
fan size??
Don't use a flex fan!!! Use a stock thermostatic clutch fan. The stocker pulls a lot more air when it is needed than the flex fan. The aftermarket flex fans are wimpy.
Old Sep 3, 2003 | 11:40 PM
Screamin T/A
fan size??
the fan i have on my engine is directly connected and i think that at highway speeds it might be decreasing my engines performance and what not.
Old Sep 3, 2003 | 11:57 PM
Torque1st's Avatar
Torque1st
Posting Legend
fan size??
Find a HD thermostatic fan setup in the bone yard and use it.
Old Sep 4, 2003 | 06:22 AM
macguyver's Avatar
macguyver
fan size??
I agree with Eric on this one. The thermostatic clutch will "disengage" until the air temp coming through the radiator gets hot enough to cause it to lock up. Then it pulls enough air to cool it down. When you're going down the road there's enough airflow that it practically never locks. When you slow down and the airflow decreases, that's when it will apply (if it needs to). It also will unlock at high RPMs.
Most flex fans just won't pull enough air to do the job properly. And they make a mess when a blade breaks. I've got a '78 parts truck in the back yard with a 400 and a metal flex fan on it. It's missing part of two blades and the shroud is broken out at the top. I can only hope no one had an arm (or more) over it when it went. I know others haven't been so lucky.
Just my 2¢
Greg
Old Sep 4, 2003 | 07:21 AM
chevdog's Avatar
chevdog
fan size??
You mentioned that the fan you have is directly connected and that you might be losing some performance, but a flex fan is going to essentially be the same thing.
I agree with the comments about using a fan clutch. I like them more from an efficiency standpoint than performance. I don't think that on a regular street engine it really makes a big hp difference. Clutch fans just work better at cooling as well as being much safer in the long run when metal fatigue starts becoming a factor.
If you decide to use the fan clutch, verify that it will place the fan about 3/4 into the fan shroud and that the fan has about 1/2" clearance to the shroud all the way around. This will help draw as much air as possible through the radiator.
If you don't have a shroud get one!
Old Sep 4, 2003 | 09:48 AM
beartracks's Avatar
beartracks
fan size??
Clutch fan and shroud should be the way to go. There are two types of the clutch fans. One is thermostatic and the other is both thermostatic and rpm controled. If you get a used one check the area in the front center. There should be a wond up spring there. If it is greasy then the silicone has begun to leak out and it may not function correctly.
If you really want performance you could get a large electric or two but you would have to fabricate a shroud to get them to work well.
Old Sep 4, 2003 | 10:54 AM
Screamin T/A
fan size??
would a clutch fan from a 79 460 work i have one just laying around?
Old Sep 4, 2003 | 03:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
fan size??
Excellent! -If it fits in the shroud right like chevdog says.
