the axle wont be centered if the front was raised 3in. look down each side and you can see it poking out more than the other. at top of tire can also probly measure from frame rail to edge of tire to get a idea how pulled over it is
kept looking at the front of my truck after I read this message and agreed my axle was off. Added the readylift track bar spacer and its centered now.
Any rubbing at all? That looks perfect! Did stepping up to the 35 hurt your mileage much? I'm assuming thats a 6.2 send there is no door badge.
Thanks!
Thanks!
Thanks, you are correct it's a 6.2. No rubbing at at all. There has been no noticeable change in my gas mileage with the tire swap in two tank fulls. The Ridge Grappler's actually improved the ride quality of the truck, and are as quiet as the stock Michelins so far.
Thanks, it really looks good! I like that set-up alot. I bought this truck fully aware of the mileage it would get, but really don't want it to be any worse!
2.5" cheapo kit, with ready lift track bar drop bracket, and moog caster/camber bushings running 285/75/18 terra grappler g2s on stock wheels. I'll try and get pics of it from the side on level ground after the alignment tomorrow. My dad's truck next to mine is almost identical stock but has my 275/75/18s on it
Love that look! Getting ready to do the same thing to my 2015. Did you have to add any spacers?
no spacers except under the springs. I did take the air dam off, painted the chrome lip black, and removed the prius catchers. I'm happy with how it turned out! I can't wait to try it out on the hwy tomorrow after the alignment to see if there's anymore tire noise and see how she handles
