8.8 rebuild
Old May 29, 2017 | 09:10 PM
jrsilverstar's Avatar
jrsilverstar
8.8 rebuild
So, happy memorial day first off. Second off ive an issue. I rebuild powdercoated and all my 8.8 in my 84 f150. Went from i think 355 open to 373 posi. New axles pinion carrier bearings shims and seals. Got everything set up. Backlash, gear patterns, and pre load and its BEAUTIFUL, time to put in the axles. Easy right? Well ive done many axle removals and installs before however never with all new parts hence my question on here. Should (with bearings installed) the new axles slide right into place or should there be some resistance from the bearings? My gut says it should slide in. But a co worker says not with new axles. Have measured old to new and all that. We dont see anything that causes cause for concern. However side note. I welded ears on the ends for a disc conversion. We have ABOUT 15 thousandths of an egg going on in the place the bearing sits Is this no bueno and causing the hang up? Note:we kmow the axles will go all the way in (hit it with a hammer and adjust for splines and itll go in. Just never have had to do that on a solid axle before. Thoughts, answers, solutions?
Old May 30, 2017 | 05:45 AM
Timehunter's Avatar
Timehunter
Doesn't sound good.
They should slide in easily.
Sounds like you warped the bearing housing when you welded on it.
Only way to save it that I can think of is to bore the bearing housing out
and put a sleeve in it.
How to bore it will be interesting.
It will be better to get another rear end and figure a way to bolt the conversion on
instead of welding.
That is,...if you plan on keeping it and it being dependable.....
Old May 30, 2017 | 05:56 AM
Franklin2's Avatar
Franklin2
Another related thread started a few days ago.
https://www.ford-trucks.com/forums/1...e-rebuild.html
Old May 30, 2017 | 07:03 PM
enriched&beyound's Avatar
enriched&beyound
dave this is the same truck/ situation
Old May 30, 2017 | 10:57 PM
kr98664's Avatar
kr98664
Please clarify something, please. Does "an egg going on" mean the bearing recess (in the end of the axle tube) is now out of round due to the welding? And the measurement you gave means instead of being round, the recess is now .015" undersize at the narrowest dimension?
If so, that's putting a heck of a squeeze on the bearings. Did you have to hammer the snot out of them for installation? If the outer race is not super thick, the bearings would probably distort to match. That would certainly explain the difficulty getting the shafts to fit.
80ford100
Jan 23, 2019 06:10 PM
RabidJade
May 28, 2016 04:09 PM
1996 5.8 Bronco
1978 - 1996 Big Bronco
Oct 25, 2010 12:51 PM
Johnnyboy1979
1997 - 2003 F150
Sep 2, 2010 10:31 PM
tpeck
Sep 29, 2009 11:20 AM
