What problems will a intake leak cause?
For the most part my van seemed to be running fairly stable. It wold stubmel a little now and then on take off but not often. Fairly often you wold feel a slight surging at very very low speeds just putting along. Other then that was the lousy gas mileage and black tail pipe..
When i removed the upper intake today I found the gasket had been torn during instillation, perhaps from the factory. I know it was leaking between the front two ports and perhaps sucking in fresh air in one spot in the same area. I think who ever installed it must have bumped the gasket when installing it. I am going to make a couple of line up temporary studs so it has to be sat down straight along with holding the gasket in place.
Here is what I found. besides the intake was black and wet looking like oil.
It's not a huge deal as long as the vacuum leak is within the limits of the PCM to compensate. The fuel/air mixture is adjusted in real time using feedback from the oxygen sensors, so the additional air would be adjusted for. There's a certain point where a check engine light would be set, but I think the older OBDI systems aren't as sensitive as more modern ones are.
If the van ran fine, I don't think there would have been any negative detriments beyond a small amount of unfiltered air being sucked through there.
chandler1981
03-27-2010 09:34 PM
ironhead86
04-09-2009 06:39 PM
drummer
12-07-2005 12:06 PM
