Popped the hot side intercooler tube.
  #31
Old 05-30-2017, 08:36 AM
bkuuz1's Avatar
bkuuz1
bkuuz1 is offline
I've seen a few people have had problems with this issue.
If a person wanted to try and prevent this so they weren't stuck on the side of the road and replaced the tubes with aluminum ones, could Ford/dealer deny warranty clams to other parts issues in the future?
  #32
Old 05-30-2017, 10:11 AM
System's Avatar
System
System is offline
Prolocutor
Received 1,200 Likes on 574 Posts
No they couldn't.
  #33
Old 05-30-2017, 10:40 AM
Khena's Avatar
Khena
Khena is offline
Does the Rudy's require a tune?
Let us know how it works once you install.
  #34
Old 05-30-2017, 10:42 AM
SkiSmuggs's Avatar
SkiSmuggs
SkiSmuggs is offline
No, it is just a replacement.
  #35
Old 05-30-2017, 10:43 AM
EO2SeaBee's Avatar
EO2SeaBee
EO2SeaBee is offline
The only ones that require a tune are the ones that eliminate the throttle body. The only one I've seen that does this is one of the two varieties built by H&S. The Rudy's keeps the throttle body, and does not need a tune.
  #36
Old 05-30-2017, 11:37 AM
bamcq's Avatar
bamcq
bamcq is offline
Originally Posted by djousma
I just ordered the mishimoto version, gets to me tomorrow, will be installed this week.
if you don't mind updating with how the install goes and after you get some miles on the miss how it does. been looking at this one but dunno with how much they want for it vs other brands
  #37
Old 05-30-2017, 11:40 AM
System's Avatar
System
System is offline
Prolocutor
The benefit of the Mishimoto is you don't have to move the remote res.
  #38
Old 05-30-2017, 11:54 AM
djousma's Avatar
djousma
djousma is offline
Will do! I hope to do it this evening.
Bingo!
  #39
Old 05-30-2017, 11:57 AM
bamcq's Avatar
bamcq
bamcq is offline
awesome appreciate it.
  #40
Old 05-30-2017, 04:56 PM
SkiSmuggs's Avatar
SkiSmuggs
Mine just arrived and I took one look at the parts and sent Rudy's Diesel a request for instructions. But, get this: There are 5 new reviews of the kit over the past few days in addition to the original 3 reviews! All positive except for the one guy whose package got lost in shipping. Those $140 kits are flying off the shelf!
To anyone who has installed theirs, can you do a write up on the installation and whether the PS reservoir needed to be offset. Pictures would be great. I am not as mechanically inclined as I was at a younger age.
I just took a look and think I have most of it figured out. The short rubber boot goes on the bottom of the intercooler with a clamp at both ends and the long curved pipe with the TB plug fitting goes into that with the fitting hole closest to the short boot. Then the long rubber boot to that with a clamp on each end. The short pipe goes directly on the TB and fastened with the original spring clip. It looks like by twisting the piping, you should be able to clear the PS reservoir. I don't see where you would relocate it to.
It is VERY important to save the retaining spring and o-ring from the TB boot to use on the new part.
  #41
Old 05-30-2017, 05:23 PM
golfmedik's Avatar
golfmedik
golfmedik is offline
Here is my write up on the H&S install that required moving the PS reservoir. As you can see in the pics, it is simply a bracket and two screws. I can't imagine any of the others being much different.
https://www.ford-trucks.com/forums/1...em-trucks.html
  #42
Old 05-30-2017, 05:42 PM
SkiSmuggs's Avatar
SkiSmuggs
Good job! Can you give a rough measurement of the offset bracket between the hole centers?
  #43
Old 05-30-2017, 06:43 PM
djousma's Avatar
djousma
djousma is offline
Ok, so, the Mishimoto is installed. Can't say for sure its installed correctly, as there were no instructions in the box. Not hard to figure out, but comes with a 4", 3.5", and 2 - 3.25" clamps. The 4" location is obvious, but not the 3.5" vs the 3.25". I took Monty's advice and used some windex to make the connections move easier for adjusting, which made all the difference in the world. PS reservoir did NOT require relocating. I had to reuse stock o-ring and spring clip even though they say they are now shipping with the kit. I guess my kit might have been prior to that change. Clamps are all 10mm, and require deep socket to torque.
I did a few full throttle runs getting turbo spooled up over 20psi, and everything held together.
I have emailed Mishimoto support for some instructions, and for the supplied o-ring and spring clips, and may have to make some adjustments based on what they come back with.
  #44
Old 05-30-2017, 06:52 PM
Ferguson65's Avatar
Ferguson65
Ferguson65 is offline
Got my H&S today. Opened the box and took a look. The adapter to the throttle body is a work of art. Very nicely machined part. Still pathetic for the money they can't include a new o ring. I need to go to the dealer for more pm22 so I will pick one up. Won't have time to install before leaving Friday though.
  #45
Old 05-30-2017, 07:52 PM
golfmedik's Avatar
golfmedik
But you'll have it with you if you need it!
Quick Reply: Popped the hot side intercooler tube.
