Popped the hot side intercooler tube.
#31
#32
#35
#36
if you don't mind updating with how the install goes and after you get some miles on the miss how it does. been looking at this one but dunno with how much they want for it vs other brands
#37
#40
Mine just arrived and I took one look at the parts and sent Rudy's Diesel a request for instructions. But, get this: There are 5 new reviews of the kit over the past few days in addition to the original 3 reviews! All positive except for the one guy whose package got lost in shipping. Those $140 kits are flying off the shelf!
To anyone who has installed theirs, can you do a write up on the installation and whether the PS reservoir needed to be offset. Pictures would be great. I am not as mechanically inclined as I was at a younger age.
I just took a look and think I have most of it figured out. The short rubber boot goes on the bottom of the intercooler with a clamp at both ends and the long curved pipe with the TB plug fitting goes into that with the fitting hole closest to the short boot. Then the long rubber boot to that with a clamp on each end. The short pipe goes directly on the TB and fastened with the original spring clip. It looks like by twisting the piping, you should be able to clear the PS reservoir. I don't see where you would relocate it to.
It is VERY important to save the retaining spring and o-ring from the TB boot to use on the new part.
#41
Here is my write up on the H&S install that required moving the PS reservoir. As you can see in the pics, it is simply a bracket and two screws. I can't imagine any of the others being much different.
https://www.ford-trucks.com/forums/1...em-trucks.html
#42
#43
Ok, so, the Mishimoto is installed. Can't say for sure its installed correctly, as there were no instructions in the box. Not hard to figure out, but comes with a 4", 3.5", and 2 - 3.25" clamps. The 4" location is obvious, but not the 3.5" vs the 3.25". I took Monty's advice and used some windex to make the connections move easier for adjusting, which made all the difference in the world. PS reservoir did NOT require relocating. I had to reuse stock o-ring and spring clip even though they say they are now shipping with the kit. I guess my kit might have been prior to that change. Clamps are all 10mm, and require deep socket to torque.
I did a few full throttle runs getting turbo spooled up over 20psi, and everything held together.
I have emailed Mishimoto support for some instructions, and for the supplied o-ring and spring clips, and may have to make some adjustments based on what they come back with.
#44
Got my H&S today. Opened the box and took a look. The adapter to the throttle body is a work of art. Very nicely machined part. Still pathetic for the money they can't include a new o ring. I need to go to the dealer for more pm22 so I will pick one up. Won't have time to install before leaving Friday though.
