Engine and Tranny Alignment
Old Sep 3, 2003 | 07:41 PM
51dueller's Avatar
51dueller
I'm aligning my engine and tranny. Since I have a 3 speed and a 4 speed mount I'm wondering if the engine and tranny are supposed to be dead center in the frame? I need to know so I can drill two holes in my homemade mount adaptor so when the engine and tranny are done it will just bolt right on.
Old Sep 4, 2003 | 07:48 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Nathan,
It depends on whether the engine is going to be centered or not. Most installations are centered, but since I'm using a Chrysler K-member, I'm offsetting mine two inches toward the passenger side to have more room for the steering box and power steering pump. First, I got the engine where I wanted it (two inches left of center and straight in the frame front to rear with the transmission attached and sitting on the rear mount but not bolted to it). Then, lined up the holes for the tranny mount to drill them.
Old Sep 4, 2003 | 01:05 PM
51dueller's Avatar
51dueller
I was sort of wondering if a Flathead V-8 is supposed to be centered or not. I know 60's Ford were offset slightly.
Old Sep 4, 2003 | 04:24 PM
mtflat's Avatar
mtflat
Ok Nathan, I just crawled down under my truck with a tape measure - sure enough the stock V8/tranny setup is dead center. Makes sense as the waterpump/motor mounts on the front of the block are symmetrical and the fan is square with the radiator.
Anything else I can measure for you while I'm down here?
Old Sep 4, 2003 | 11:08 PM
51dueller's Avatar
51dueller
Thanks I thought so but wanted to be sure.
Old Sep 5, 2003 | 10:40 PM
51dueller's Avatar
51dueller
Well I got both holes drilled and everything seems to be in order. I will weld some angle iron on my adaptor to strenghen the sides.
