Dang This Sucker Runs Hot!
I have a very similarly built engine, from the sounds of it. Mine runs between 195 and 205 on the trail, meaning crawling, going very slow. I have a dual 12" fan on an aluminum high flow radiator that measures 26" x 18".
Is the temp sending unit in the stock location, front of the block passenger side of the water pump?
I'm having the same issue with my freshly rebuilt 400. Like yours, I have a slightly more aggressive cam, & 4BBL Holley carb. I also have a brand new aluminium radiator:
CC433
Mine heats up past 220 quite quickly just idling. I had the timing set at 12* static & was running without vacuum advance hooked up. I'm thinking mine's a timing issue, simply because I've eliminated everything else.
CC433
CC433
CC433
And, hook up yer vacuum advance being sure the breaker plate moves freely and wires therein are not brittle.
Got to test drive a little bit yesterday after hooking up my vac advance hose to the distributor and putting the correct t-stat back in. Running at about 210-215 now, but will need to idle in traffic a little more to see f it's consistent or not.
Planning on installing an aluminum radiator soon, and seeing Champion has a 3-row for under $250.
#29
