Sponsored by: Kumho
F150 prerunner
Old May 23, 2017 | 10:08 PM
Alvin91's Avatar
Alvin91
F150 prerunner
I currently have an F 150 FLAR SIDE and I want to make it a prerunner, I would like to know what lift kit I should buy and what modifications are might need to do this.I want to keep it as stock looking as possible with water lest 16 to 20 inches of travel.
Old May 24, 2017 | 04:02 AM
glockholiday's Avatar
glockholiday
What year F150? I take it it's 2wd? Engine? trans?
Old May 24, 2017 | 08:15 AM
Alvin91's Avatar
Alvin91
1994 and 5.0 and stock auto trans 2wd
Old May 24, 2017 | 10:13 PM
glockholiday
Still need to know if 2wd or 4wd for someone to better help you.
What I'm finding is if you want a true "long travel" set up it will require some welding and fabrication which any offroad shop can handle. Camburg is a big name in suspension but there kits require some of these mods to install them.
If you buy a "lift kit" like this one 2.5in Suspension Lift Kit w/N2.0 Shocks for 80-96 Ford 2wd F-150 Pickup [422.20] | Rough Country Suspension Systems® that is all it will be, lifted. It won't ride much better if any, and basically will just give you more ground clearance and allow you to run bigger tires.
DeluxF150
2015 - 2020 F150
Apr 25, 2016 05:55 PM
bayley_dl
Jun 4, 2009 02:37 PM
jdency
Aug 21, 2004 10:51 AM
BuiltFordTough32
Apr 8, 2002 06:55 PM
