ez wire problem
Old May 22, 2017 | 09:45 PM
papabills54's Avatar
papabills54
ez wire problem
Hi, got my 54 ford running after pulling engine and trans. I also pulled my bed and redid the bed wood and installed a 45 gal in bed tank. so got it drivable but found out I had no running lights or brake lights but I do have directional in the back. its been running with an EZWIRE harness and was working before. IM thinking I've got something grounded that s not supposed to be cuz every time I turn the head lights on it blows the tail lamp fuse. any other ideas would be appreciated. I have the two wire 56 rear lamps .
bill
Old May 23, 2017 | 04:53 AM
apkarian100's Avatar
apkarian100
Could it be the headlight switch causing the problem? What kind of headlight/taillight switch are you using?
Old May 23, 2017 | 06:44 AM
GreatNorthWoods's Avatar
GreatNorthWoods
You definitely have a short somewhere. Since you pulled the bed my guess is a wire going to the rear got pinched or something within the tail light itself is shorted. Follow the wires back to the tail light and you will probably find it...
Old May 23, 2017 | 09:33 AM
petemcl's Avatar
petemcl
Sorry, anything that we would tell you would be a pure guess. The best thing that you can do is to dive in with a good ohmeter. You didn't mention smoke and flames so that is a good thing.
Old May 23, 2017 | 02:28 PM
CharlieLed's Avatar
CharlieLed
Your brakes and turn signals share the same wire. The running lights are on their own circuit. As Pete suggests, get a ohmmeter and check the running light wire to ground...I bet you will find a short. Trace the wiring and I am sure you will find the source of your problem. Good luck...
Old May 23, 2017 | 04:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Just curious why you need a 45 gallon tank?! Planning a cross-country trip?
Old May 23, 2017 | 05:04 PM
CharlieLed's Avatar
CharlieLed
Ballast....
Old May 23, 2017 | 06:21 PM
pbsdaddy's Avatar
pbsdaddy
Can't stand gas station sushi!
79cherro
Electrical Systems/Wiring
Aug 6, 2016 07:04 AM
jrm21
Nov 27, 2011 11:00 PM
txsoldier74th
Mar 12, 2011 07:28 PM
thewheelman
2004 - 2008 F150
Oct 28, 2009 08:29 PM
marshmudler
Jun 12, 2004 08:49 PM
