oil pressure problem
Old May 22, 2017 | 08:36 PM
gwalker12's Avatar
gwalker12
73 F100 2wd C6 little to no oil pressure, any pointers on removing pan and replacing oil pump. water pump, fan and shroud are off.
Old May 22, 2017 | 08:49 PM
mountain dewd's Avatar
mountain dewd
First thing you need to confirm is why you have no oil pressure. You can have the best oil pump in the world and you won't build any oil pressure if your problem lies elsewhere. You could have anything from a leaky/loose oil pump, worn out main bearings etc. When you drain the oil ad pull the pan, DO NOT clean the pan before inspecting it internally. "Read the tea leaves" and look for any particulate matter/metallic sheen that may be the smoking gun you're looking for.
Old May 22, 2017 | 11:18 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Could be a bad sending unit, faulty OEM gauge...do you have a T 'ed in aftermarket one? I would or trouble shot the easy ones before all the rest that is coming your way.
Old May 23, 2017 | 05:30 AM
boingk's Avatar
boingk
1) Check the gauge. It may be leaking or giving bad readings.
2) Check for leaks - is oil coming out of anywhere it shouldn't be?
3) Check your oil level - if its low that's a guarantee as to why its got no pressure.
4) When was the last oil and filter change? Old oil and clogged filters really bring down pressure.
4) If all of that doesn't help... then you need to dig in further. Engine out, pan off, check the oil pump and check the main bearings. Likely a full rebuild, or at least new bearings, will be in order. A 'cheap' way around this may be to test a few engines at the local pick-a-part and simply fit a new engine.
- boingk
Old May 23, 2017 | 09:09 AM
gwalker12's Avatar
gwalker12
First off, Thanks guys for the replys. Truck has a working oil pressure gauge that works, Just bought this truck, oil and filter was just done, nothing unusual when I drained this oil out. speedo reads 97K who knows how many times its been around. front cover has been off tel tale blue permatex, not sure if pan has ever been down pan, came lose with one shot with rubber mallet. does the starter need to come out, and motor mounts disconnect from engine or frame mounts. guy I bought truck off of supplied pump, screen, fresh oil and filter. ran into problem with his daily driver forced sale of this truck.
Thanks again!
johnfl
Jan 24, 2017 05:05 PM
pjenks
1997 - 2003 F150
May 6, 2014 10:13 PM
BiG_AnT
1983 - 2012 Ranger & B-Series
Jul 11, 2005 09:37 PM
ilwill77
18
May 17, 2005 11:21 PM
tosman
May 20, 2003 02:12 PM
