Battery cable questions
Old May 21, 2017 | 06:40 PM
jazz77's Avatar
jazz77
Hey all. I finally broke down and ordered some custom battery cables for my 2001 7.3 Excursion. Long story short, a relative was helping and now he's not and I'm not sure where he disconnected the passenger lower ground. I think it might be the same bolt which holds the grommet for the positive but I'm not positive (ha-ha).
My second concern is that this was originally a Wisconsin truck and every bolt is rusted. I am unable to take off the smaller ground wire at the frame. This wire is separate on the kit I have and I'm wondering if it's necessary. Thanks.
Old May 21, 2017 | 07:14 PM
dieselss's Avatar
dieselss
You can ground to the engine block close to the starter, just watch the exhaust. Then run a jumper from that to the frame, just make sure it's clean metal and clean bolts.
Old May 21, 2017 | 10:08 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Jazz, it mounts to the harness that goes down to the starter. Right on the side of the block where that harness is attached for stability. So, technically it is the same bolt that holds the grommet for the positive.
Old May 21, 2017 | 10:16 PM
jazz77's Avatar
jazz77
Thanks for the info guys. I will attach it with the grommet brace (which I had a hell of a time getting from the old cable to the new) and just drill a new hole in the frame for the smaller cable.
bkgeig
Dec 16, 2016 11:42 AM
Shake-N-Bake
Sep 22, 2014 11:27 PM
bigrayjr
Mar 23, 2013 04:55 PM
HighOctane23
Jul 3, 2012 06:33 PM
MatthewC
1978 - 1996 Big Bronco
Sep 19, 2005 02:29 PM
