brake lights
Old May 19, 2017 | 02:48 PM
bzerk56's Avatar
bzerk56
brake lights
well bezrk never quits , now i dont have any brake lights theres power to the switch , none coming out , ground ??
Old May 19, 2017 | 04:25 PM
jniolon's Avatar
jniolon
old and in the way
I'd check the output of the switch for 12 vdc.... then check your grounds
john
Old May 19, 2017 | 07:01 PM
bzerk56's Avatar
bzerk56
yeah i did check for 12 must be grounds then ,, thank s
Old May 19, 2017 | 10:26 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
If there is power in to the switch but none coming out that is not a ground issue, that is a contact issue within the switch.
Old May 20, 2017 | 07:30 PM
bzerk56's Avatar
bzerk56
ok agreed but 3 switches ???????????im at a complete loss
Old May 20, 2017 | 07:33 PM
bzerk56's Avatar
bzerk56
ok this particular switch mounts behind a wilwood adjustable proportioning switch , if that matters
Old May 20, 2017 | 07:40 PM
raytasch's Avatar
raytasch
Believe Nothing
Is this a pressure switch or a mechanical switch? First step, jumper across both switch terminals and see if the lights work.
Old May 20, 2017 | 07:59 PM
bzerk56's Avatar
bzerk56
its a pressure switch old screw in type
Old May 20, 2017 | 08:02 PM
bzerk56's Avatar
bzerk56
ok ill try it
Old May 20, 2017 | 08:14 PM
bzerk56's Avatar
bzerk56
nope no lights !
Old May 20, 2017 | 08:25 PM
raytasch's Avatar
raytasch
Believe Nothing
Are you using a meter or test light? If you have known power to the switch, have jumpered across the switch, then there has to be power at the other side of the switch. This means the wiring downstream toward the light itself, or the light itself or the ground is bad. Is this a rewire job with new wiring? Have you checked the ground at the lamp housing? Do you have a known good bulb?
Old May 20, 2017 | 09:53 PM
bzerk56's Avatar
bzerk56
yes this is new wiring and it worked great till i replaced the front calipers which i know has nothing to do with it at all , and taillights work great
Old May 20, 2017 | 11:06 PM
bzerk56's Avatar
bzerk56
im using a test light , doubtful that both bulbs and taillights are bad ,
Old May 20, 2017 | 11:27 PM
CharlieLed's Avatar
CharlieLed
This particular switch operates on the front brake line circuit. Since you worked on the front brakes I would have to assume that your actions caused the failure. Usually a pressure switch will fail when there is not enough pressure in the line...I would check for air in the line. Bleed thoroughly, and if you are running Wilwood calipers with dual chambers be sure to bleed BOTH sides. Good luck.
Old May 20, 2017 | 11:37 PM
bzerk56's Avatar
bzerk56
no im not i have new calipers , and bled the system ,i have a wilwood proportion adjustable valve
