Huskey fender well inserts
Old May 19, 2017 | 10:24 AM
fordquist's Avatar
fordquist
Installed the Husky fender well inserts. 30 minutes start to finish. 4 screws per side. Fairly straight forward install. They do have some pucker in the center above axle which may be for spring clearance, or may lay flat over time. Two screws on each side will require a shorter screwdriver if install is done with the wheels on.
​​​​​​. Overall happy with appearance and ease of install. Well worth $100 and 30 minutes of my time.
Old May 19, 2017 | 10:54 AM
AMXDREAMER's Avatar
AMXDREAMER
The fender liners sure clean up the fenderwells and allow the bodylines to show instead of the side of the bed.
Old May 19, 2017 | 11:57 AM
TXLO-1's Avatar
TXLO-1
Tires and Lift
What size tires and lift are you running. Did you lift the back? How much?
Old May 19, 2017 | 12:15 PM
fordquist's Avatar
fordquist
2.5 ready Lift level. 35x12.50. I think the camper package makes it set a little higher, but no lift.
Old May 19, 2017 | 12:40 PM
charlesweaver3's Avatar
charlesweaver3
I put these on my truck 2 weeks ago. Glad to know that yours also pucker out a little in the middle.
Heat23
Oct 26, 2018 11:16 PM
adam10
May 25, 2015 07:51 AM
lucaslaw
Nov 9, 2010 05:01 PM
metalskater2
May 23, 2010 08:26 PM
homesteader
13
Mar 16, 2010 08:36 PM
