Can I fully assembly dash before installation ?- frame-off restoration
Can I fully assembly the dash [instrument panel] prior to installing it in my cab? By assembly, I mean install the instrument cluster, radio, ac/heat control, glove box, switches, etc. before dropping it into the bare cab.
I am in the process of a frame-off "restoration" of my 1978 shortbed F100. I think it would be easier if I fully assembled the dash before installation. I don't want to scratch the new interior paint. It seems that the assembled dash would be installed at the factory to reduce manufacturing costs.
Thanks all!
P.S. Looks like the '73 - '79 group has the most activity.
Thanks all!
No you can't, there are way TOO MANY things that have to be removed to hook them up.
Heater cables need to be hooked= control has to be pulled out.
Cluster needs to have the speedo & circuitry plug which means it would have to be removed
Glovebox has to be removed.
