1.5 or 2 Ton Truck?
Rick,
You should start your own thread here, titled something like "1946 Fire Truck, getting it running". That fire truck is in great shape.
I'm about 4 hours north of you near Salem and would like to visit at some point. I'm a volunteer at the Yamhill County museum.
Do you know about Bob Drake, an early Ford parts business located in Grants Pass? They have the green bible on CD. That probably won't be the only thing you purchase from them.
As I mentioned on Ford Barn I will scan the V8 times article for you. I can also scan the 47 truck owners manual. It will pretty much apply to your 46 too.
Tom
Tom
Hi there.
We just acquired a 1946 Ford Fire Engine based on a Ford commercial chassis. Wheelbase is 134", more or less (measured with tape measure). Tires on front are 7.50x20 with HUGE lug nuts; Dual tires on rear. We're trying to locate a chassis repair manual or ANYTHING that will help us to restore this baby. I notice that you're also in Oregon, so perhaps close enough for you to come see it here in Medford Oregon. Here's a web page showing some photos:
Any help will be appreciated.
Rick
Medford Oregon
Rick
Medford Oregon
We're not planning to repaint it in the near future. Way out of our limited budget.
Rick
I am very interested in this thread as I own a German (Cologne) built Ford truck 1944, I don't at all understand the American designations all I know is the my vehicle is what we Brits call a three tonner meaning it has a 3 ton payload this is borne out buy the typpenschild (data plate). So what is the correct American designation? It has the same rear axle setup mentioned earlier in this thread.
The following users liked this post:
Tire Size
A 7.50-20" tire at each position generally signifies a 4.33" or 5.00" wide wheel set (measured across the inner rim base). Thus a 1.5 ton rating I think if none of the other heavier duty features (springs, etc) are present. The 5.00" rim could be fitted with 8.25" tires, but generally they would be mounted on 5.50" or 6.00" rims. The 6.00" rims, two speed axle, and heavier springs would suggest the 2 ton rating to me. Stu
A 7.50-20" tire at each position generally signifies a 4.33" or 5.00" wide wheel set (measured across the inner rim base). Thus a 1.5 ton rating I think if none of the other heavier duty features (springs, etc) are present. The 5.00" rim could be fitted with 8.25" tires, but generally they would be mounted on 5.50" or 6.00" rims. Stu
Rick
Rick,
Tom
Tom
If you're ever down this way, give me a shout. I'd be happy to give you a tour of our project.
Rick
#28
#29
#30
