Hey Guys - I am new to at this and looking for some insight. I just purchased a '77 Ford F150. Per the vin number, it was originally built with a 351W, but the guy I bought it from told me that it was a 460 engine. I can't find any identifying plates on the engine or under the hood. Can anyone help me to identify exactly what size engine it is? Any quick tips or tricks?
Also, I am replacing the chassis wiring harness and am redoing the instrument panel cluster. I have the original instrument panel connector but am having a difficult time finding the right open barrel terminal to fit. Is there a specific one I need, or can I use whatever I can get to fit?
351W = 6 valve cover bolts per side; 460 has 7; 351M (and 400) has 8.
1976/79 F100/350; 1976/80 Econoline & 1978/79 Bronco use a different instrument cluster back & printed circuit board with Oil/Amp GAUGES than they do with Oil/Amp WARNING LAMPS.
