No reverse lights - switch?
Old May 15, 2017 | 08:33 PM
stupid red ranger's Avatar
stupid red ranger
Hi guy's,
I've got a 2008 Ranger FX4, 4.0L with manual transmission.
Recently I noticed that I have no reverse lights. I have to parallel park on busy streets from time to time, so this is a safety issue that I need to fix.
I checked the bulbs, both seem fine - would be unlikely that both bulbs would die simultaneously. I checked the fuse. Again unlikely unless the reverse lights were on their own independent circuit. 10A fuse looks fine too.
Last thing I can think of is a switch. I checked my Haynes Manual, there is no mention of it, which is odd, usually my manual is quite good.
Any idea where the switch is located? Any experience with swapping this out?
Thanks!
Old May 15, 2017 | 08:46 PM
Jklnhyd's Avatar
Jklnhyd
This video is of a 2001, but it might be the same. I didnt watch the whole thing.
Old May 15, 2017 | 09:29 PM
stupid red ranger
Thanks for that. He didn't say if he had an automatic or a manual. No idea if it makes a difference under there or not, I haven't looked yet.
Old May 16, 2017 | 01:44 PM
CBB9M's Avatar
CBB9M
Originally Posted by stupid red ranger
Hi guy's,
Thanks!
Go out there with your DMM (get a $5 cheapie from HF if you don't have one) and see if there is a good ground on one contact and +12V at the bulb socket when it's in reverse. If not, use the DMM to check for +12V at the reverse light switch and for continuity of the switch when the vehicle is in reverse. The switch will be located on the tranny, and schematics for the entire vehicle are available at no cost on bbbind.com I would encourage you buy a copy of the factory service manual as these are the holy grail for information and are, of course, used by professionals who have no time for missing and/or crappy info. Haynes is to auto repair what a rattle is to a baby.
Old May 26, 2017 | 02:38 PM
stupid red ranger
Got it. Was the switch - ended up pulling one from a scrap transmission. There is enough room to access it if you have the right socket.
Interesting little switch, its a ball switch looks pretty robust, but for some reason mine died.
Thanks FTE forum
asalinasz73
15
Jan 4, 2018 11:31 AM
Firelizard
May 27, 2017 06:13 PM
bkks744
Jul 7, 2008 06:10 PM
Dukernc
Jan 14, 2007 09:28 PM
stigedis
1997 - 2003 F150
Jun 10, 2006 08:25 AM
