pitman arm info
Old May 14, 2017 | 02:09 PM
giorgio.fo's Avatar
giorgio.fo
pitman arm info
hi guys,
just finished to reinstall the pitman arm on my new steering gear shaft.
torqued the nut to 228 ft-lb but it still sitting lower than it was before.
installed it by hand first, than used a wrench to push it up while the gear box was in the wise than finished it from under the truck.
is it ok if it doesn't go all the way up or should i push it with the big braker bar?
thanks
Old May 14, 2017 | 02:26 PM
Shawn MacAnanny's Avatar
Shawn MacAnanny
It doesnt need to go all the way up. I always run it on tight with an impact and recheck it in a couple weeks. I've had some loosen up.
Old May 14, 2017 | 03:40 PM
cadunkle's Avatar
cadunkle
As long as splines are fully engaged it's fine. It's never had two sit in exactly the same spot. Manufacturing tolerances are wide enough to notice change in fitment on these.
Old May 14, 2017 | 05:32 PM
giorgio.fo's Avatar
giorgio.fo
thanks guys
Aaron-71
Aug 12, 2018 08:32 AM
Dutter 2
15
Feb 12, 2016 08:55 PM
Brian085
Jul 22, 2012 10:01 AM
mrdavidkendall
Dec 29, 2004 05:46 PM
jonnygorgo
Jul 19, 2003 10:45 PM
