Ordering Process/ VIN Availability Question
Old May 11, 2017 | 12:15 PM
GoldenDomer's Avatar
GoldenDomer
Quick question for you guys that know a lot more about the ordering process than I do... If Ford chat says that my order is "in processing" does that mean that Ford has picked up/ accepted the order? And if that is the case then a VIN should be assigned within a week or so correct? I only ask as my dealer uses a 3rd party company to order trucks and from what I have seen they don't relay all information and what does get relayed definitely isn't in a timely manner so I am trying to track everything on line myself. Really sucks spending as much as these trucks cost and not being able to track them better. Thanks in advance guys.
Old May 11, 2017 | 12:47 PM
Johnpsz's Avatar
Johnpsz
Here are the basics..
"In Order Processing" Status:
  • Order from dealer --> Ford getting and accepting the order = Varies mine was next day, but we knew the order pick-up was teh following day and why I went in when I did, other guys took weeks for the order to get picked up base on allotment allocation issues between that dealer and what they had in stock already.
  • Ford Accepting the Order --> VIN = Varies a little but normally under 2 weeks, some have seen in 5 days.
  • VIN --> Window Sticker = ??? This is the biggest unknown to us, as this is the period of time Ford is doing all the leg work to schedule, make sure parts and accessories for your build are available and so forth.
  • NOTE: Window sticker is normally available online the day after it is generated in the system.
"In Production" Status: (normally happens just after the Window Sticker becomes available)
  • Window Sticker --> Build date = 7-8 days depending on the time of day your truck enters the 23 hour build process, 2 days after "In Production it is getting body and paint, the paint dries for 2 days before the interior and everything else is installed and the truck attached to the chassis.
  • NOTE: The Build date is normally available online (ETIS and Cotus) the day after it is generated in the system.
"Awaiting Transport" Status:
  • Build date --> getting loaded for transit = 1-7 days, this varies if you have spray on bedliner (normally a day or 2 is needed for bedliner) or if you are waiting for more vehicles heading in the same direction as your train/convoy.
"In Transit" Status:
  • getting loaded for transit --> getting to the dealership = varies too much, but we found the Ford system assumes about 15 - 21 days (7 day window 2-3 weeks out) for this in the initial ETA they provide. So we can do some reverse math off the ETA to find build week, then subtract a little more to get an approximate W/S date.
So in other words, normally once you get the W/S, you know pretty much when things start happening, before the W/S it's an unknown waiting game.
Old May 11, 2017 | 01:24 PM
GoldenDomer
Thank you sir. This helps out tremendously. My issue is I know that Ford normally picks up orders on Thursdays which is why I checked with Ford Chat this morning but they wouldn't even tell me if a VIN had been assigned yet. The worst part of this is the fact that my salesman/ dealership isn't even given the information on a regular basis. I will just start bugging my salesman next week for him to bug the other company until I get my VIN. Thanks again guys.
Old May 11, 2017 | 02:11 PM
Blwnsmoke's Avatar
Blwnsmoke
I'm not sure if you mistyped and meant that the dealer/salesman isn't giving YOU the info on a regular basis. I can tell you that dealerships get updates every day.
I can understand why many don't.. they are trying to sell vehicles and with the dozens of customers, hundreds of vehicles on order etc.. it takes up their time. But then again, this is what differentiates a salesman from an excellent salesman.
The guy I go through which I fly 800 miles out to pick up and drive home updates me several times a week if not almost daily. There were times I was getting emails at midnight with an update (he has access at home that most do not).
Old May 11, 2017 | 03:23 PM
GoldenDomer
I stand corrected. The dealership does get a printout every day that lists out all vehicles they have on order. I was shown the printout but didn't really have a chance to see all of the information listed other than an ETA. I also think one of the big issues is that the dealership is a Ford and Chevy dealership side by side. My salesman is primarily a Chevy salesman but the truck obviously is going through the Ford side. As you stated above I'm sure they get busy doing everything else and don't have time to fill me in on every step of the process. I guess I was just hoping to be kept up to speed a little more. We'll see how the rest of the process plays out and I'm sure once the truck shows up I forget all about all of this.
Old Jan 17, 2020 | 02:57 PM
John Lange's Avatar
John Lange
Talking
Thank you for this explanation. I found this thread by searching google and came up with the thread as one of the results. My truck went "In Production" yesterday so should be done within the week.
Old Jan 27, 2020 | 12:13 PM
John Lange's Avatar
John Lange
What does it mean when status changes to "Released to Body Company" Thank you in advance.
Old Jan 27, 2020 | 12:19 PM
puddintank's Avatar
puddintank
It's going to the place that does the spray in bedliner.
Old Jan 27, 2020 | 01:15 PM
zmetalmilitia's Avatar
zmetalmilitia
I think your dealer has to go check for updates, I don't think he gets notified of updates, so its up to him to get the updates and relay them to you. My order has been "in processing" since the day I ordered it, nearly 5 weeks ago, luckily my dealer had allocations, but still waiting on a VIN.
Old Jan 27, 2020 | 06:53 PM
John Lange's Avatar
John Lange
I am not sure of other people and their dealer, but I know mine has gotten updates. Just not very forthcoming with them. They rely heavily on the salesperson to get you the updates but unless I go in to get one, I would not have gotten one because the salesperson is trying to make a living and are trying to sell the vehicles off of the lot to make their money. Just it seems some dealers and salespeople are more to keep you satisfied for your repeat business and such where other dealers are only interested in making their money and do not care about you.
Old Jan 27, 2020 | 07:03 PM
Parksoffroad's Avatar
Parksoffroad
Does Ford actually paint the trucks as they are building them? I toured the Toyota NUMI plant in Fremont CA some years back and the finished and painted parts all came together as the truck went down the conveyor belt. All the body paint was done before the truck was assembled. Interesting that they might not do it the same way.
Old Jan 27, 2020 | 09:31 PM
SBC's Avatar
SBC
Passing arrival
So mine has said “passing arrival” for about four days now. Any idea what this means?
Old Jan 29, 2020 | 12:06 AM
John Lange's Avatar
John Lange
Here is a video about KTP. It shows in part of it how they prime and paint the bodies.
Old Jan 29, 2020 | 12:42 AM
Parksoffroad
https://vimeo.com/80375637
OK, thats more like what they were doing at the Toyota plant as well. I was able to walk the assembly line and take pictures back in 2007, here is a body dropping onto the frame during assembly. Very similar to what they were doing at the Ford plant.
Old Jan 31, 2020 | 06:27 PM
John Lange's Avatar
John Lange
Do you happen to know for the "In Transit" status what it means "Arrived at Junction Point".
Edit: I found out what it means. It has to do with the railroad and when they pass a certain point, called a Junction Point, the tracking system for the railroad will update where the rail-car is at in the system.
