New from British Columbia 1986 F250
Old 05-10-2017, 12:56 PM
mdlowry's Avatar
mdlowry
mdlowry is offline
Hello. I have owned this truck for 20 years. I bought it when it had 47,000km (29,000 miles) It now has about 300,000km (180,000miles). I'm not exactly sure because I changed the dash out for one with rpm gauge about ten years ago. It has always run great except about 8 years ago I had a intermittent faulty ignition module that would cut out and then come back which led to a spectacular back fire and blew out three exhaust manifold bolts on each side. I had to pull the heads to drill out the bolts but after that it always ran to the high temp side. I replaced everything to do with cooling including sender and dash gauge, but still hot. The only thing I can think is maybe I put the head gasket in wrong which I knew about but still not sure. So am in the process of pulling it down again. The first time I managed to put it back together with all the stock emissions **** on because I wanted to keep it bone stock. Not this time I am deleting it. It is just too hard to do anything with that **** on there. So I will be hanging out at the 86 section to try and get info on other people that have done this.
I know long intro, eh. Funny fact I have owned this truck for 20 years and never knew they were called bull nose until I came here.
Thanks for having me, Mike.
Old 05-11-2017, 10:23 AM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
Welcome to the site
Tony
Old 05-12-2017, 03:48 AM
Zip's Avatar
Zip
Zip is offline
Welcome Mike from a fellow BC'er. That is one clean looking truck you have there.
Once again welcome. Enjoy all the info you will get.
tymahaney
New Member Introductions
11-08-2018 11:54 AM
OLDBLEU66
09-19-2015 10:40 AM
tesia1971
07-16-2015 09:32 PM
MrBuick (Magnum)
08-19-2013 01:56 PM
freirefishing
01-03-2008 09:23 PM
Quick Reply: New from British Columbia 1986 F250
