Sponsored by: Real Truck
Question after track bar replacement
Old May 4, 2017 | 11:23 AM
XLmountainman's Avatar
XLmountainman
4wd High
Truck is a stock except for aftermarket shocks '15 F350. I put a Ford stock replacement bar on and now the truck pulls to the driver side, steering wheel goes to the left as well. Is it normal to have to get an alignment after replacing the track bar?
Old May 4, 2017 | 12:53 PM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
If the track bar is a different length from the one you replaced, that might affect the position of the steering wheel when the wheels are straight. But that should not cause the truck to pull to one side. I think there's something else going on there...
Old May 4, 2017 | 01:29 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Why did you have to replace the track bar already? Seems odd to change that out and not touch drag link, tie rod, sway bar, etc?
Old May 4, 2017 | 01:42 PM
XLmountainman
4wd High
Bushing was shot, had too much play
Old May 12, 2017 | 09:44 AM
Ford744's Avatar
Ford744
Track bar replacement shouldn't have affected your alignment but maybe. ?
Since you say it's "pulling", it's not your steering wheel alignment (drag link). I'd have my alignment checked. I'd be looking at the Toe, but more importantly Caster. If you have different caster angles between left to right your truck will pull one way or the other. But again, changing the track bar shouldn't have affected your caster angles. Strange.
Section179
Nov 24, 2022 10:11 PM
macdiesell69
6.7L Power Stroke Diesel
Dec 16, 2013 12:16 AM
mylandscaper
Feb 8, 2010 11:40 AM
aklim
Feb 25, 2006 06:56 PM
