Amp. meter issue?
Old Apr 30, 2017 | 03:23 PM
Steve1920's Avatar
Steve1920
Amp. meter issue?
My amp. meter on my '86 F-350 shows discharge but a voltmeter on the battery says it's putting out 14 volts. It starts fine- like theres no charging problem- it turns right over. And I have a new regulator and starter too.
Any ideas on what my trouble is?
Thanks.
Steve
Old Apr 30, 2017 | 07:30 PM
Franklin2's Avatar
Franklin2
I bet some wiring has been done out at the alternator and the wires are backwards. Has some re-wiring been done around the alternator/starter relay/solenoid?
Old Apr 30, 2017 | 08:53 PM
kr98664's Avatar
kr98664
Good point. You mentioned the regulator and starter are new. Why were they changed? Did the ammeter problem start before or after that?
With the engine off, lights off, doors closed (so the dome light is off), and all other electric loads off, where does the needle sit? It should be centered.
Engine off, turn on the headlights. Does the needle deflect to the left like it should?
How about disconnecting the battery? With no electric flow possible, the needle should be centered. This should give an idea if the ammeter is defective. Not very likely, but simple to rule out.
Old Apr 30, 2017 | 08:56 PM
Steve1920's Avatar
Steve1920
No, no rewiring or alternator work has been done. That's part of the reason why this problem is so puzzling!
Steve
Old May 1, 2017 | 08:40 AM
Gary Lewis's Avatar
Gary Lewis
Does the ammeter show a discharge with the key off? Some of the gauges don't have the needle right on zero when there is no current flow.
Old May 1, 2017 | 09:26 PM
Steve1920's Avatar
Steve1920
I replaced the regulator thinking that must have been the culprit when everything else seemed to be correct. Not sure about whether the starter or amp. gauge acted up first. The starter had been on its way out for a while- turning over slower than usual and then not starting once it was hot. Cold starts did okay but with some heat in it- no dice. Did the starters excessive draw do something to my gauge?
I'll have to check where the needle sets with the ignition and lights on and off.
Old May 1, 2017 | 09:32 PM
Gary Lewis's Avatar
Gary Lewis
The starter's draw doesn't go through the gauge nor its shunt.
BigBlocker0248
May 14, 2016 06:09 AM
Coz2122
26
Jul 6, 2015 07:32 PM
fishindave11
1978 - 1996 Big Bronco
18
Apr 17, 2012 04:38 PM
scotts77
Jan 17, 2004 05:13 PM
