Center link questions/ problems...
Old Sep 2, 2003 | 04:29 PM
supergapurple's Avatar
supergapurple
Please help!! I have to (well allready took apart) replace my center link, but I am stuck. The old bolts and cotters are not broke, and I havnt broken anything, but...
I unbolted all bolts and took out pins, I pushed the inner tie rod out, but now the center link will not slide out of the pitman arm nor the spindle (I think that is what it is attached to on the passenger side)
Question is: do I need a special tool? (like the "steering wheel puller" that is recommended but seldom used) and HOW is it done??
Thanks folks for any help.
Old Sep 2, 2003 | 05:37 PM
ranger429's Avatar
ranger429
it is called a pickle fork, there are 3 sizes so make sure you get the correct one
Old Sep 2, 2003 | 06:09 PM
supergapurple
which should I get? Or does it depend on MY truck?? The stores here all have a (quote) "tie rod end puller, that works the same way as a pickle fork..."(end quote)
tanks again!
Old Sep 2, 2003 | 06:11 PM
ranger429's Avatar
ranger429
that is the one. the difference will be in the width of the fork between the two prongs
Old Sep 2, 2003 | 06:15 PM
supergapurple
Thanks, due to rain and transportation (wife at work) I will get it tommorow...I will post more tommororw Thanks!
Old Sep 2, 2003 | 06:16 PM
ranger429's Avatar
ranger429
any questions at the parts store as to what size you need have them look up the part you are replacing to verify the correct size
