Heavy rain while parked, now missing badly
I replied on the other thread. Had your same exact problem but I eventually got a misfire code for #6 and replaced that cop. since then I have replaced all the cop's and she purrs like a kitten. I bought the cheap ones from rockauto at about $10 a piece. Kept two of the old ones and a 7mm nut driver in the center console as spares. Seems like it would be worth the $100 on cops before you took it to the dealer. Maybe even another $50 for plugs.
Good luck.
I went to take out plug #1 and it was tight. Tight to the point that i was afraid of snapping it off. I know plugs should not be that tight in anything.
Stewart
Diagnosis was #1 coil bad, and #8 coil intermittently bad. They advised to do all 10 plugs and boots and of course replace #1 and #8 coils.
Drove it home 50 miles last night and it is purring like a kitten.
Also, left rear caliper seemed to be sticking/dragging on occasion. 'slider' pin/bolt was in bad shape so they fixed that.
....and, when i dropped it off, as I was waiting for my ride to get home, a rear brake line blew when they went to pull it in the bay. Talk about good timing. Glad that didn't happen while i was out of town with the trailer tomorrow.
When I bought the Ex, i got under it and looked at the lines, they all looked good. Apparently there is an area in the lines that are prone to rusting near the rear axle...idk.
The original P0720 code for the output shaft speed sensor was not an issue at all as reported widely on the interwebz and on here. I have 2 spare OSS's just in case though.
As far as the shop goes, the owner is a Ford master tech...They are a high performance shop specializing in all things ford (and all other makes/models/types of course), especially turning street legal mustangs into drag strip monsters. They had a Dodge charger hellcat up on a lift with some DOT legal street slicks on it...not sure what they were doing to it.
They also are gearing change gurus so im gonna look into getting some gear work done when i decide to put bigger rims/tires on.
I feel warm and fuzzy about taking the EX to them and not a dealer where i was getting no good vibes from the 1/2 dozen dealers i talked to.
They can supply aluminum if requested.
Scored some of these as well locally. Couldn't pass up the deal. Unsure if i'll use them or not. These are not the ones i have, but the same.
Now i need to re-read the aluminum vs steel spacers debate....ugh
Stewart
I didn't know what the Timesert inserts were made of until I called them.
They normally supply all their inserts in stainless unless stated, but can supply them in aluminum upon request.
They didn't indicate which would be better, but any Timesert insert is probably better than a helicoil.
I guess my preference would be the stainless.
(Ok, confusing me is easily done, but that's beside the point)Way back when Ford was getting around to offering a different fix for this problem, instead of the "replace the head" action Ford had previously instructed their techs to take, Lock-N-Stitch became the only Ford recommended aluminum insert provider to fix this problem.
That was many, many years ago, and they used to advertise that on their website, but I just now checked and it looks like they are now only Ford approved.
Stewart
I'm thinking i'll just replace the other 8 coils myself. At least I'll know that i have 10 new coilds. The shop replaced #1 and #8 and that fixed the misfire(s) and has been running great since July and 6 roadtrips worth about 5000 miles.
The common thing that is occurring is it rains.
New or old parts, something is getting wet.
Did you try flooding the windshield with a garden hose?
I get what you're saying but the truck sits in rain all the time. Replacing #1 and #8 didn't keep the truck from getting wet in the past 4 months.
I'll throw a garden hose on it and see what i can find. I am familiar with the 'bridging the gap' molding at the hood/firewall area.
