1978 - 1996 Big Bronco
Steering Gear Box Leakage
Old 09-05-2003 | 06:17 AM
RyanGruhn's Avatar
RyanGruhn
Opps,
I did not mean that in a offensive way at all. Just asking, thank you for your help and I am going to fix he seal today.
Thanks!
Old 09-05-2003 | 02:47 PM
RyanGruhn's Avatar
RyanGruhn
My friend thinks it might be the bearing and/or bushing inside the steering gear box. You think there is a chance, or should I go ahead with the seal replacment and not worry about it? He said that with out seeing it.
Ryan
Old 09-05-2003 | 07:17 PM
DW2455's Avatar
DW2455
I f it drove okay to start with without excessive play, then id give the seal replacement a try. DW
Old 09-05-2003 | 08:15 PM
_GEEZER_'s Avatar
_GEEZER_
If you have excessive play in the steering, yes, it may be a bearing (or a few other potentials,) but if it is the leaking you're worried about, replacing a bearing won't fix it. Regardless, you'll need to replace all the seals anyway if you're gonna replace bearings.
