1966 - 1977 Early Broncos
ultimate cooling?
Old Sep 2, 2003 | 01:43 PM
spartamouse1's Avatar
spartamouse1
ultimate cooling?
was running a logging road over the weekend. drove it for about 5 miles and engine temps went to 210. stopped and let it cool, went to low range and got the rpms up and helped but occasionally it would get to 200. so now i want a ultimate radiator. any suggestions??
Old Sep 10, 2003 | 12:30 AM
RCrawler's Avatar
RCrawler
ultimate cooling?
Go with a quality aluminum radiator. If everything else is in good shape cooling system and engine wise, it will make a huge difference. I have seen temp drops of up to 30 degrees. Also, make sure that your fan shroud is in decent shape and that the fan is close enough to the radiator to pull air.
Jason
Old Sep 10, 2003 | 08:08 AM
spartamouse1
ultimate cooling?
been looking, that is kinda of what i thought. any one any better than the other or go for price?
my 5.8 lightening crate motor just arrived yesterday. figured if the old 302 ran a little warm things would just get worse.
Old Sep 28, 2003 | 05:02 PM
67EB's Avatar
67EB
Are you sure it is your radiator? Have you checked your thermostat? Timing? Shroud? Fan Clutch? I would say to save your money and make sure you have a problem with your new motor... but if you just bought a 5.8 lightning crate motor... another $400 for an aluminum 4core should be just a drop in the bucket.
Old Sep 29, 2003 | 08:19 AM
spartamouse1
everything else is new. i am going to run the new motor with the stock (but new) 3 core radiator just for ha ha's too see if it was the old 302 or not. then put the new radiator in.
Old Oct 1, 2003 | 09:41 AM
Nicholas's Avatar
Nicholas
Thumbs up
Sparta, keep us up to date with the progress and post some pics if it is possible???
Nick.
