1978 - 1996 Big Bronco
Ignition Woes
Old Sep 2, 2003 | 12:54 PM
wliebhard's Avatar
wliebhard
Unhappy Ignition Woes
Help Me, Please!!!!
I am installing a Cummins Diesel in my '85 Bronco. Everthing is going good, except the ignition. Does anyone know what wires are the 'Run, Start, Acc.'?? I've tried to trace them from the colomn, but to no avail. I am mostly concerned with the wires protruding thru to the engine bay. I can start the engine with a hand switch, so i just need the Ford's ignition wires!!- Thank you for any help- Will
Also, if anyone need info on what I've had to go thru to this point, I can help as much as possible. (the 351 just wasn't doing it for me anymore...)
Old Sep 2, 2003 | 04:32 PM
DW2455's Avatar
DW2455
Ignition Woes
Man this should be a kickA.., Bronco i would love to know how it turns out, as for as wires go my haynes book has wire schematics in the back?
Try this with your test light and ignition swith, i tried to decipher this crap in this schematic but there a (blue) wire and a (yellow) wire with a green fuse link in it both should be connected to the starter solenoid over by the battery,? let me know if they work. DW
