'86 F-350 Stakebed Dually Starter Issue
#31
#32
I purchased one for under $54 delivered for my manual transmission 460 truck.
Automatics are under $45
https://www.dbelectrical.com/product...92-96-m-t.html
#33
Yes, the diagram is an awesome "infographic". Dare I recommend two changes? Change "Solenoid" to "Relay", since that's what it is. And it's more common for the main battery-to-starter (motor) cable to come right from the battery. That way, the wire from the battery to the relay doesn't have to be that huge; just big enough to power the rest of the truck.
KISS is all I have to say
Dave - - - -
#34
So, I KISS'd it and just ran a new wire. Works great!
#35
Guess it depends on your definition of "simple". To me, an extra connection between the battery and starter motor is LESS simple than a direct cable. Since you need a new wire anyway, why not just get a battery cable that's made for a newer truck? Plus, that's fewer terminals stacked on that junction point terminal on the relay, which IMHO is the more "simple" solution. Again, it's all in the interpretation.....
#36
#37
#39
Oh, there's my diesel bias again. I forget that the wire from the relay to the starter is big enough for the starter motor current. So all you really need is a new _small_ wire from the relay to the starter solenoid. Follows the KICK (Keep It Cheap, Kilroy!) principle....
Dave ----
Playa_fl
05-09-2009 02:54 PM
allisonmo2
03-12-2009 08:52 PM
seizure911
02-17-2008 10:54 PM
