Rides Hard
Old Apr 24, 2017 | 08:27 AM
jcweis1's Avatar
jcweis1
Rides Hard
I never had a Expedition before now and finally got my new to me 1998 Expedition Eddie B 4 x 4 with 164,000 miles done.
Put all new shocks and both trailing arms and all new tie rods.
After the first drive on the road after the alignment this things rides hard and you can feel every bump in the road. I have 32 psi in all the tires.
I had a guy who drives a F150 4 x 4 said he could not believe how hard it rides also.
Are Expeditions all like this? Anything be done or wrong with it?
Old Apr 24, 2017 | 08:56 AM
alloro's Avatar
alloro
The hard ride could be the tire choice, some tires ride softer than others. If you check the numbers (size) on the installed tires or the names do they have an LT or XT at the end? Those suffixes indicate it's a truck tire and those have stiffer sidewalls and give a harder ride.
Old Apr 24, 2017 | 10:29 AM
swagfu's Avatar
swagfu
It could also be the type of shock you installed. If you got a heavy duty off road type shock it would ride hard as well.
Old Apr 24, 2017 | 12:04 PM
jcweis1's Avatar
jcweis1
the shocks are Gabriel from autozone nothing special, the tires are just a cheap street thread design. the guy I had drive it has a f150 4 x 4 and he said it rides a lot rougher than his truck. You can hear the Expedition go over every ripple on the road sucks
Old Apr 24, 2017 | 08:15 PM
pdqford's Avatar
pdqford
Does that EB have rear air suspension?
If it's not pumped up they can ride on the axle,
And that can be one hard ride.
Old Apr 25, 2017 | 04:04 AM
Skauber's Avatar
Skauber
Depends, I have an EB (granted it's a 2005, but still) which was delivered with standard coilover suspension all around, so I guess it depends on which boxes the original owner ticks on the purchase order.
Old Apr 25, 2017 | 09:13 AM
jcweis1's Avatar
jcweis1
No air ride on this one.
Could it be that I installed and tightened the trailing arms while it was on the lift while the axle was suspended?
The control arms are rusted but not enough to worry about breaking, not sure if these could be the cause.
Old Apr 25, 2017 | 09:57 AM
pdqford's Avatar
pdqford
Could it be that I installed and tightened the trailing arms while it was on the lift while the axle was suspendede.
That may be it. It would be worth a try to tighten them with the arms at ride height.
Old Apr 25, 2017 | 12:14 PM
lv2race's Avatar
lv2race
I put on Gabriel's from AutoZone and you could feel every crack and pebble in the road. The wife was not happy with her "new" ride, so I got Monroe's from RockAuto and the jittery stiffness went away.
Old Apr 26, 2017 | 08:48 AM
jcweis1's Avatar
jcweis1
I will call Autozone and see if they will take them back and try another brand of shocks and let everyone know if it was the Gabriels
Old Apr 26, 2017 | 11:08 AM
jcweis1's Avatar
jcweis1
Autozone said they will return & refund cost of the Gabriel shocks.
I ordered Monroe's from rock auto and will install this weekend and tighten the trailing arms at the ride height and let everyone know if it helps the ride.
Thanks
Old Apr 26, 2017 | 11:32 AM
swagfu's Avatar
swagfu
Should be interesting to see if this fixes it. Hope it works for you.
Old Apr 26, 2017 | 02:27 PM
lv2race's Avatar
lv2race
You do have a 4X so I'm sure your ride is rougher than my 2WD Expo, but you should notice a difference. I left the Gabriels on for a few months hoping the ride would get smoother, but that never happened. For me, the Monroe's made a big difference and have been on for a couple of years without complaints. I hope it works for you as well!
Old Apr 26, 2017 | 03:09 PM
Skauber's Avatar
Skauber
As far as my shop manual goes, it says to tighten the suspension component to torque specs at ride height to avoid stresses on the suspension.
Old May 1, 2017 | 08:28 AM
jcweis1's Avatar
jcweis1
Results!
Changed the shocks from the AutoZone Gabriel's to Monroe's and re-tighten the trailing arms at the ride height and now rides like it should!
THANKS to everyone's help
