I have a 64 F100 with a 235....among any other projects and interests. This truck is not what I consider a project truck. It doesn't have many miles, but has spent its life in Illinois. So the body isn't good and body supports I have even had to give attention to.
But it's a driver. The problem has been that it isn't reliable, and I live many miles from anywhere I go. 8 miles to nearest town. 15 miles to work. I can work on the reliability with continued work to the fuel system and ignition...and I have to figure out why that clutch still chatters.
But even then, 60 mph is taxing for any regular driving. I don't need it to be fast or quick. But a little more enjoyable at highway speed. And I don't need a lengthy project.
Are there pretty straight forward trans swaps or drivetrain swaps that mostly use the brackets/mounts that I currently have? I was even wondering about 300/6 combos and if they drop right in.
I have done some searching, but most want to go V8. I just want to go easy. Well, and affordable. If they are readily available parts to find.
Due to the way the engine is mounted, nothing "drops right in" on a 1961/64 unless you are using the original 223 I-6 (no such thing as a 235) or 292 V8
Ooops. 223 it is. Number not so dummy!
Thank you for the info.. I was hoping there were some items over the years that fit the bill. But if were easy.....
I guess nothing for overdrive for the 223?
Wolf, The odometers roll back to 0 at 100,000. The truck is 50 years old, take an easy number 10,000 miles a year times 50 years and hold your low miles as tight as you want.
Side mount conversions are available, a 302 AOD would be a good setup but is itself getting dated. You might want to start a plan before you hit the wall and have to do something now. There are Eco-boost, V-6s, turbo diesels, to choose from. Start making plans and do something 4-6-10 months from now. You are not against the wall yet.
I converted to a 400/t18 but yea not seeing anything that is going to be easy. Any newer motor you might go to will required fabricating all new mounting and probably changing driveline lengths a bit.
Are you sure you have a 223? I think the 240/300 were also used in 1964. If that's the case you might rebuild or get a reman 240/300. Add a new clutch kit, surface the flywheel and be back in business.
The Borg Warner T5 (now owned by Tremec) was used extensively in North American production vehicles including Ford and GM. Due to this there is a near endless combination of gears that can be installed and this means you don't need 4th to be a direct drive. You could have 2 overdrive gears if you want to. You will have to research the gear combos but I have read this in hot rod magazines in the past. Junkyards are crawling with camaros and mustangs so mix and match!!
