Sponsored by: Real Truck
Gauge Cluster
Old Apr 22, 2017 | 07:37 AM
super01duty's Avatar
super01duty
Gauge Cluster
I have a 2001 F250 XL 4x4 with a 5.4, the cluster lights are going dim and the low fuel level light is out. I have a 2002 F450 XL 4x2 with a v10, the engine is blown. Can I swap the gauge cluster from the F450 into the the F250? The F450 has the electronic odometer and transmission temp gauge.
Old Apr 22, 2017 | 08:18 AM
alloro's Avatar
alloro
You sure the dimmer isn't turned down or otherwise going bad?
Old Apr 22, 2017 | 08:32 AM
super01duty
Dimmer is working, the lights are dimmer I some areas and brighter in other areas. Also the the fuel level low light is out.
Old Apr 22, 2017 | 10:29 AM
Mike189677's Avatar
Mike189677
Swapping the clusters is not going to work sounds like you need to pull your cluster out and replace some bulbs and see what you got.
Old Apr 22, 2017 | 02:01 PM
super01duty
So will it not work because of different wiring? The reason I ask is I do like the tranny temp gauge
Mcrafty1
Apr 7, 2019 06:26 AM
Tractionless
6.4L Power Stroke Diesel
Jul 19, 2017 03:50 PM
shabazz18
Mar 15, 2016 11:42 AM
HotrodSmurf
Jul 8, 2013 09:15 PM
